Hello !
I am having trouble forcing a different resolution on my TV Out than the one of my primary display. I am using a Geforce 7900GT, I have a LCD screen with 1280 * 1024 @ 60Hz as primary display, and I use a DV Cam on my TV out in order to record, so I set the clone mode in the config panel.
Now because 1280 * 1024 > 720 * 576, I have panning on my camera. In order to disable this, I would like to get a fullscreen image on my camera. In order to achieve this, I need the TV resolution to be 720 * 576 (or smaller), and I can't do this because the nvidia control panel keeps telling me that the test failed.
How can I force this resolution ? I already tried with the old config panel, TVTool and Riva Tuner without success. Please help me sad.gif
Cheers,
TheParadoX
I forget what NVIDIA calls it, but you want to use theater mode for the TV output. Whatever you play in a media player will appear full screen on the TV output, even while windowed on the main monitor.
True. However, I am trying to record games and not movies, and the theater mode only works with movies
I need a shrinked clone image of my primary image
I believe you have to use 1024x768 or less to get clone mode (full screen) working with TV out.
Thanks, I found that out too. It's better than nothing, I can actually play with that resolution
Custom resolution Problem X4500HD
By madmat01 in forum DVB / IPTVReplies: 5Last Post: 15th Sep 2010, 08:28 -
Converting Avi To MP4 Ipod with custom resolution
By zander20 in forum Video ConversionReplies: 2Last Post: 28th Nov 2008, 14:59 -
Force mencoder to use mod 16 resolution
By sumpm1 in forum LinuxReplies: 1Last Post: 13th Sep 2008, 18:00 -
Having issues with Clone Mode in Catalyst Control Center...
By Jaxel in forum ComputerReplies: 1Last Post: 25th Feb 2008, 06:08 -
Decrypter "Brute Force" mode can damage the writer, or produce ba
By Bruxo in forum DVD & Blu-ray WritersReplies: 5Last Post: 2nd Dec 2007, 16:26
