I downloaded an MP4 file today but I'm having trouble converting it to DVD in FAVC. Here's the info on the video file I got from MediaInfo.
General
Complete name : J:\movies\Once Upon A Mattress 1964.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 1.81 GiB
Duration : 1h 17mn
Overall bit rate : 3 334 Kbps
Encoded date : UTC 2008-07-19 14:14:07
Tagged date : UTC 2008-07-20 23:25:15
Video
Format : AVC
Format profile : High@L5.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : avc1
Duration : 1h 17mn
Bit rate mode : Variable
Bit rate : 3 175 Kbps
Width : 718 pixels
Height : 480 pixels
Display aspect ratio : 4/3
Frame rate mode : Variable
Frame rate : 29.970 fps
Minimum frame rate : 29.963 fps
Maximum frame rate : 29.981 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.307
Stream size : 1.73 GiB (95%)
Writing library : x264 core 56
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=5 / brdo=0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=1 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=599 / keyint_min=25 / scenecut=40 / rc=crf / crf=25.5 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / pb_ratio=1.30
Tagged date : UTC 2008-07-20 23:20:08
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Duration : 1h 17mn
Bit rate : 153 Kbps
Maximum bit rate : 171 Kbps
Channel(s) : 2 channels
Channel positions : L R
Sampling rate : 48.0 KHz
Resolution : 16 bits
Stream size : 85.0 MiB (5%)
Text
Format : Timed text
Codec ID : tx3g
Duration : 1h 17mn
Bit rate mode : Constant
Stream size : 360 Bytes (0%)
Any idea what I need to get or do or whatever to make this work? (Free tools only if possible, please. Thanks.)
I got it demuxed but now when I import the video file, I get an error message that DGAVCIndex needs to close.
I'm beginning to think I got a bad file, which I'm going to be mad if I did, since it's of a VERY rare program and I spent about five hours downloading it.
Are you sure you checked 'raw stream' (rather than mp4) as demuxing option? In case of video-only in mp4 container DGAVCIndex won't work.
Perhaps your input video and/or audio has errors?
Please be specific in what error messages FAVC and DGAVCIndex are giving you
Are you able to play the video in a directshow player, like MPC, without error? or are there "glitches"? -
If it helps, I had to install the newest QuickTime just to view the video. The other programs I have won't even open it.
The error message isn't really anything other than what used to be "Windows has performed an illegal operation" in 95 and 98. Except now it's something like "DGAVCIndex has encountered a problem and needs to close."
Yes, I made sure to check raw streams.
FAVC doesn't really give error messages. It just never gets to the video analysis part. -
Your video uses AVC video and AAC audio. You need a proper splitter and codec to play it back. QuickTime includes it's own, but FAVC doesn't rely on QuickTime installed codecs.
If you install haali media splitter, ffdshow (set h264 to "libavcodec" in the video configuration, and set AAC to "libavocdec" in the audio configuration), you should be able to play back in direct show based media players, like MPC
If you can play it back using direct show filters - like in MPC, then FAVC should work, either directly or with an avisynth script.
The other possibility is that the text file is causing problems. You can take it out with YAMB (re-package the .mp4 without the text file)
Another option is to use avidemux to generate DVD compliant MPEG2 stream, then author it yourself using GUIforDVDAuthor, or DVD Author GUI, or DVD Styler etc... (ALL free)
And of course, the possibility of errors still exists. -
How do I make the AVS script in DGAVCIndex? The only thing I can find is the "AVS Template," but that doesn't seem to do anything.
Problems converting DVD to AVI, MP4
By azikiwee323 in forum Newbie / General discussionsReplies: 3Last Post: 25th Jun 2009, 13:33 -
Problems Converting MP4 to DVD
By spartan25000 in forum Video ConversionReplies: 2Last Post: 15th May 2009, 14:54 -
problems converting to mp4
By jedibri17 in forum Video ConversionReplies: 8Last Post: 28th Dec 2007, 23:20 -
Problems converting from MP4
By bboypkj in forum Video ConversionReplies: 2Last Post: 27th Nov 2007, 21:57 -
Converting VOB file to MP4 file. Video is perfect, audio is nonexistent.
By jdfrosty in forum ffmpegX general discussionReplies: 6Last Post: 17th Jul 2007, 19:31
