LOL if you read the spec, DTS HD. AC3 HD,etc alone can add 35% to the file size in a m2ts container just because of ecc code. if you are interested in archiving and not re-compressing , try makemkv it rips the sutibable tracks out to a mkv file and plays nicely with MEGUI for re-compressing if need be. the only downsidde is there is no d-show fileter for BD sups. but with a little knowlege , bdsub2sup and mkbvmergegui can remedy that. otherwise yes, total media center 3 (NOT POWER DVD!!!!!) can play back the BD folder from the HD that tsmuxer makes.
Results 31 to 37 of 37
if all else fails read the manual
imgburn converts BD folders to iso as faster as your HDD can transfer, usually about 3 minutes on my systemOriginally Posted by dannyboy48888
ocgw
peacei7 2700K @ 4.4Ghz 16GB DDR3 1600 Samsung Pro 840 128GB Seagate 2TB HDD EVGA GTX 650
https://forum.videohelp.com/topic368691.html -
not aimed @ you, but to everybody that feels the need to change a blu ray to something else in situations where it is not necessary, because they usually do a lot of work for nothing, and do more harm than goodOriginally Posted by carlos28355
If you playback movies from your PC converting a blu ray to something else is not necessary, even if you want to shrink it down to BD-5 converting it to another file type is not necessary
Even if you are streaming to a media extender file conversion is not necessary
leaving the blu ray struture intact and mounting the iso to a virtual drive and playing w/ full gfx acceleration capable high-end gfx card on proper hardware gfx acceleration capable software I can play a blu ray and stream multiple blu rays simutaneously all over my house while reencoding a blu ray
Now if you just have to put a blu ray on you ipod, by all means. go for it
imho
ocgw
I have to agree that some folks are making this harder than it has to be.
BTW, lots of people have no problem using Daemon Tools to mount and play ISOs. It is true though that a minority do have trouble. Since there are others available free of charge (including one from SlySoft), it's irrelevant to the question of whether to use disc images of Blu-Ray discs or converting to some other container.Pull! Bang! Darn! -
im getting alot better at this thanks guys for your help especially ocgw im sure u hate me by now lol.
No way buddy, you "get it", my lil' rant was aimed @ other peeps in general lolOriginally Posted by carlos28355
ocgw
Hi Everyone
Could someone shed some light on this problem im having
im using tsmuxer to create avchd from a mkv & ac3 audio so all is compatible
after the avchd is finished - it produces 2 streams - 00000.m2ts & other think it was 00190.m2ts - the 190 doesnt play in vlc and to be honest isnt that big a file - it also produces file in the playlist folder and all other folder where 00000. appears
i use used imgburn to burn this and my dvd says incompatible - so i went back and deleted all files that were 00190 and re burned - dvd says incompatible - the stream 00000 plays fine on computer - and if i burn say an avchd that someone else produced dvd plays fine - i checked my folder to another and it had the same amount of files & folders after the 00190 were deleted - can anyone suggest what the problem is or why tsmuxer is producing 2 streams
Blu-ray + DTS-HD authoring with tsMuxeR
By Zerrax in forum Authoring (Blu-ray)Replies: 1Last Post: 11th Nov 2011, 19:30 -
tsMuxer Blu-ray outputting, audio delay?
By dabezt in forum Authoring (Blu-ray)Replies: 0Last Post: 25th Apr 2011, 05:35 -
replace subtitle of blu-ray main file on tsmuxer 1.10.6 problem
By ps3z in forum Authoring (Blu-ray)Replies: 0Last Post: 8th May 2010, 15:02 -
tsmuxer errors with media type 15 when creating blu-ray content
By syeager in forum Authoring (Blu-ray)Replies: 4Last Post: 31st Mar 2010, 16:52 -
No subtitles when using tsMuxeR 1.10.6 to convert mkv to Blu-ray
By mistercool in forum Authoring (Blu-ray)Replies: 14Last Post: 20th Mar 2010, 14:28
