Hi
Is there any option or plug-in for Virtual Dub to encode the whole video stream of dvd?
I mean, in most of dvd encoding softwares, the program can detect the entire video stream and encode it into a single avi files, but it seems that in virtual dub, you should encode each of *.vob files to avi and then merge them.
Check 'extended options' if it doesn't load all the files automatically.
VD was never really designed for DVD to AVI conversion.
What I've done is to use VOB2MPG with a decrypted DVD file and then use VD with the MPEG plugin or just use VD Mod. Open the large MPEG file from VOB2MPG and encode it as you want.
But most times, a program like AutoGK or FairUse Wizard would be much easier. You just need to decrypt the DVD first. DVDFab Decrypter works well for this.
Virtual Dub 1st & 2nd Pass Encoding
By OrchestraAndChoir in forum Video ConversionReplies: 10Last Post: 22nd Jul 2012, 07:20 -
Is New iPhone A Dud?
By budwzr in forum MacReplies: 68Last Post: 12th Oct 2011, 20:26 -
virtual dub xvid codec encoding w/o profile
By caner12 in forum EditingReplies: 7Last Post: 5th Jul 2009, 12:08 -
xvid encoding in Virtual Dub, stats file?
By Xavier in forum Video ConversionReplies: 4Last Post: 10th Feb 2009, 08:46 -
Which printer, exchange required for dud R230
By mikesbytes in forum ComputerReplies: 1Last Post: 5th Mar 2008, 05:51
