Greetings,
Hopefully this is the correct place to post this thread. None of the forum sections really seem to fit it exactly...
Anyhow, I have MAGIX Movie Edit Pro 11 and 14, and I love the programs to death, and I use them frequently. But admittedly I don't know all of the features of the program, nor do I know if this is even possible but I thought perhaps someone here might be able to answer this.
Does anyone know if it's possible to import 3D objects into Movie Edit Pro, and than manipulate and animate them? If so, how is it done? Which file type do the 3D objects need to be?
If Movie Edit Pro can't do it, would anyone be able to recommend to me a program where I could import 3D objects and animate and manipulate them to make a short film (probably around five minutes long), that isn't overly-complicated and is fairly simple... and runs on a PC?
I really don't need a complicated fancy program, I'm just trying to put together a short animation using various 3D objects by simply moving them around, rotating them, and so on. I don't even need to be able to make fancy special effects (though that would be neat).
This may be a stupid question, but I'm really not sure of the answer. Any help or advice would be much appreciated.
Thank you for your time!
Results 1 to 1 of 1
Magix Movie Edit Pro 17 - Help
By volotre in forum EditingReplies: 1Last Post: 12th Apr 2011, 11:27 -
Problem with Magix Movie Edit 14 - Sound muted between objects.
By Jo The Veteran in forum EditingReplies: 1Last Post: 3rd Jun 2009, 17:49 -
Magix Movie Edit Pro and MP4's
By uihawks89 in forum EditingReplies: 2Last Post: 6th Jun 2008, 00:09 -
MAGIX Movie Edit Pro 12 problem
By Rein Engel in forum EditingReplies: 0Last Post: 21st Sep 2007, 13:40 -
Magix Movie Edit Pro 11 Encoder
By SCDVD in forum EditingReplies: 0Last Post: 7th Jun 2007, 17:09
