    Oct 2008
    Germany
    Hi all
    I searched the forums but did'n find what I need, so here's my question:
    How do I transcode AVIs for my dreambox 600 PVR?
    Inside the avi theres DivX video with mp3 sound, I need a MPEG2 TS with MPEG Audio.
    I thought vlc would do, I used VLC 0.9.2 with these setting:
    Encapsulation: MPEG-TS
    Videocodec: MPEG-2, Bitrate 2048 kb/s, Scale 1
    Audiocodec: MPEG Audio, Bitrate 192 kb/s, Channels 2
    It actually did play on my dreambox, but I got bad block artefacts around moving objects.
    What did I do wrong, or how do I do it right?
    Thank you in advance
    Oct 2008
    Germany
    Thank you, I'll try.
    Wow, this has 2 GUIs plus command line. I'll take the qt4 GUI...
    Now.... what options do I have to use...?
  3. Avidemux claims support for dreambox. You can check their forum for assistance too.
    1) video sidebar => DVD (lavc), configure your settings (e.g. bitrate)
    2) audio sidebar => MP2 (Twolame), configure your settings (e.g. bitrate)
    3) format sidebar => MPEG-TS (A+V)
    4) save with extension (e.g. "myfile.ts")
    If your source was low quality to begin with, your output will look worse (garbage in = worse garbage out)
    Oct 2008
    Germany
    Settings that worked for me:
    video bitrate: "2pass avg. bitrate", avg. rate 4096, max bitrate: 9000, min bitrate 2048
    audio bitrate: 192...
    dreams
