I've heard a lot of people talk about the success they've had with using firewire and dv camcorders. That got me wondering are there any video devices outside of camcorders that can transfer video/data directly to a firewire connection?
For example do any high end TVs, PVRs or VCRs have firewire connections? Better yet are there any converters that takes a signal from maybe a composite, s-video or coaxial connection and convert it over to a firewire format? A converter like that could be a million dollar invention.
Originally Posted by Leander
http://www.synthetic-ap.com/tips/firewireconverters.html
Some of the newer D8 camcorders from Sony do conversion in both directions, so for the home user it's pretty much all-in-one. -
Canopus ADVC-100 DV/Analog Converter
There are several threads here discussing this device. It works in both directions. :PPIV-2.4G ASUS MB, 1G Mem, WinXP -
I saw a post somewhere ( I think on this forum) where someone used a camcorder, with the appropriate connections of course, as an adaptor (not through tape first) to record from a VCR through a firewire card. I think the software used was called Power VCR and it gave an mpeg as the captured file so you could go straight to VCD without going through avi which would be pointless given the low quality of VHS. Does anyone remember this and does anyone know the procedure in more detail.?? I would like to be able to do this as I don't have an analog capture card.
AFAIK DV Format is a fixed format (720x576 PAL or 720x480 NTSC) and you can only use full or half resolution. As "capturing" via Firewire is in reality a file transfer, you have to stick to the DV format for caturing (this is mpeg-2).If you want a lower resolution, you have to convert this format (always giving an .avi type) to a different format later.
knock down price check for some good offers
stagAthlon xp-2400
60 gig.h/d.7200rpm
256mb ddr ram
Asrock:-k7s8xe.sis 748 chip set m/b
Win xp pro
Hollywood-dv bridge/Belkin firewire card -
I have datavideo-1000. I connect my JVC DV camera directly (hru firwire cable) with Datavideo. Play and record. CD is ready.
Quality is so good. I stopped using computer for converting videos.
New comp, no fire wire. Pls advice
By jazu in forum Newbie / General discussionsReplies: 4Last Post: 27th Feb 2012, 00:20 -
Can I capture/copy DV directly to DVD MPEG2?
By shina00 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 17th Nov 2011, 06:16 -
Hi8 player to DVD recorder - S Video cable, RCA or Fire Wire?
By Dixie Paul in forum Newbie / General discussionsReplies: 10Last Post: 5th Jan 2010, 08:56 -
By Dixie Paul in forum DVD & Blu-ray RecordersReplies: 1Last Post: 3rd Jan 2010, 11:33 -
can usb replace fire wire cable??
By Berghof in forum Newbie / General discussionsReplies: 2Last Post: 8th Dec 2007, 22:48
