    Oct 2008
    I am using DVD Decrypter and AutoGK to make AVI's, and it's going good except when I am trying to rip anime. I want to have a .vob file for ONE episode with only Japanese Audio and English Subtitles. The problem is this, the file is one big PGC file. Here's a picture..... In DVD Decrypter I check "Enable Stream Processing" and I check the Video, Japanese Audio, and the English Subtitles.
    and when I rip it, it rips fine and the .vob is fine. But the problem is when I load the .ifo in AutoGK it says the length is 1:08:48. That's the whole PGC length, not the one episode that I wanted. When I play the .vob in VLC Media player it plays the Japanese audio and I just have to manually enable the subtitles. So what I'm asking is, is there a way to make AutoGK recognize the length of just one episode, not the whole PGC? I know I posted a a lot of information about something so trivial but I wanted to make my point clear.
    Thank you to anyone who can help!
    I appreciate it.
    P.S. This place rocks!
    May 2005
    Toronto ||*||
    Rip and split by file( looks like they're about 1gig each or size)
    or use DVDshrink to rip each title and deselect the unwanted streams.
  3. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    I suggest one of the following:
    1.) pgc.NET
    2.) PgcDemux
    3.) PgcEdit
    Please note this list is in no particular order.
    Anyway of these I've only actually used pgc.NET but I think all three will do what you want (knock on wood).
    - John "FulciLives" Coleman
    P.S.
    You should rip the entire DVD first to the HDD and then use one of these programs on that output. Use DVD Decrypter or the newer more up-to-date DVDFab HD Decrypter.
