Hi all,i was wondering if anybody could tell me if there is a program that would let me take parts off various dvd's and put them on on disc, i.e. songs from movies such as movies from the 50's, i hope someone can help, and i hope you understand what i mean lol
thanks in advance
Paul
Use any ripper software to select the segments you want to keep.
Then the simplest way is to use a dvd authoring program that accepts vob files (the files that you would get from ripping the dvd) and then make your new disc. Tmpgenc Dvd Author is such a program.
Once you have the clips you want you would start your vob-input compatible program and add your clips one at a time. You can make them sequential like a new movie but it would jump from cut to cut. You'd have to use an editing program to make the smooth transitions from scene to scene.
You can also leave the clips as they are and just make them selectable from a menu. You'd have clip a be its own menu button, then clip b would get a menu button, and etc. etc....
You can pretty much do it however you like. However you are limited to 99 clips per dvd title set as that is the dvd structure limit.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Is there a program to edit HDDVD like Clown_BD can edit Blu-ray?
By c627627 in forum Authoring (Blu-ray)Replies: 0Last Post: 3rd Jan 2011, 23:35 -
Why does the video I edit in Cyberlink look darker after I edit it and post
By Chubby Johnson in forum Newbie / General discussionsReplies: 1Last Post: 30th Jun 2010, 05:08 -
Any program to edit .ts or .m2ts files?
By yic17 in forum EditingReplies: 3Last Post: 18th Jan 2010, 00:29 -
Removing bad segments using program "Video Edit Master"
By risp73 in forum Newbie / General discussionsReplies: 0Last Post: 30th Aug 2008, 15:52 -
need help in choosing a format after video edit (DV then edit then DVD)
By shade_2 in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2008, 13:13
