I am wondering if any software out there can do the same slide show like this?
I'm trying to make a slide show and put this into a dvd.
Example:
http://www.rockyou.com/show_my_gallery.php?source=ppsl&instanceid=124005728
With the heart clip from here and a greyscale heartshaped jpg, it's possible to do something like this: http://download.videohelp.com/tin2tin/Hearts.html in DVD slideshow GUI.
Here's how to do it:
Download and install DVD slideshow GUI.
Download this jpg and add it to the transitions folder of DVD slideshow GUI.
Download this video clip called heart2.zip and unzip it into the Posteffects folder of DVD slideshow GUI.
Download this effect file and place it in the posteffects folder of DVD slideshow GUI.
Start DVD slideshow GUI.
Choose your resolution under Project Settings if you are in the US. you want NTSC.
Then choose in the Project Settings the post-effect Heart.avs
And under Import settings(same menu-window) Heart.jpg as transition.
Then add/import your images in the main window.
The preview will properly stutter because of the hearts are too heavy to process realtime.
So render to ex. mpg and when you're ready for your dvd then chose burn...
Photo Slide Show in AVCHD
By chrisnewton in forum Authoring (Blu-ray)Replies: 8Last Post: 23rd Apr 2011, 04:40 -
Making an interesting start to a slide show
By avz10 in forum Newbie / General discussionsReplies: 4Last Post: 17th Feb 2010, 00:57 -
dvd w/ video & picture slide show
By hymnatr in forum Authoring (DVD)Replies: 2Last Post: 20th Dec 2008, 11:51 -
DVD Slide Show Duplication
By KLouis22 in forum Newbie / General discussionsReplies: 3Last Post: 28th Aug 2008, 08:27 -
Adding slide show to a movied DVD
By leungf in forum Authoring (DVD)Replies: 2Last Post: 6th Sep 2007, 09:55
