I've been experimenting with the USB on my PS3. I tried DVD files and noticed it would
play the vobs w/o any problem. So I just transferred some movies over to the external Hard disk
I was using by putting each of them into their own folder. However some of the vobs play fine and some
have no audio. I find it strange that one vob from a movie plays with audio and the next just doesn't.
When I click on audio on the PS3 remote it indicates no audio.
Am I doing something wrong or is the PS3?
Tony
I haven't tried that in awhile with my ps3. Is it a fat32 drive? Could the vob be over 4gbs and not being recognized by the ps3?
Also is it a dts or dobly track? It shouldn't matter for the ps3 since it does both but perhaps make note of it and see if it makes a difference. Then you might need to rerip the dolby track. - if it is dts don't forget to try it through your amp and not the tv as there are practically 0 tvs with a dts encoder built in meaning you'll need to use a dts enabled amp....
just some ideas to kick around.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
I ran into this problem last week with vob files (no ifos) on a dvd with the PS3. The 1st vob in a titleset played with audio but the remaining vobs had no audio. The vobs had two AC3 audio tracks.
If the vob files were converted to mpegs using Mpeg-vcr (no re-encoding), they would play with audio.
Have you noticed only the 1st vob played with audio?
AverMedia USB HD-DVR + PS3?(need help)
By Gskyace in forum Capturing and VCRReplies: 2Last Post: 30th Apr 2011, 20:59 -
Put more than one video on a USB HDD for PS3
By jjblackisback in forum Software PlayingReplies: 1Last Post: 30th Apr 2011, 14:23 -
USB AVCHD for ps3 doesnt work
By caner12 in forum Video ConversionReplies: 2Last Post: 10th Aug 2009, 15:28 -
m2ts for PS3 on USB stick or DVD
By leopardx in forum Media Center PC / MediaCentersReplies: 2Last Post: 14th May 2009, 09:56 -
USB Audio To PS3
By Guiboche in forum AudioReplies: 4Last Post: 8th Jun 2008, 09:46
