Results 1 to 21 of 21
    Mar 2008
    India
    Which has the better compression in terms of quality - XviD or Latest DivX build?
  2. In my personal testing/observations they are about the same.
    DivX encodes a bit faster, and the difference is larger when you have more CPU cores
    h264 offers significantly better compression/quality, especially at low bitrates
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    If you are willing to poke around in the configuration for Xvid then there are those who will tell you it is better than Divx. I use AutoGK, which limits my poking, but with the full version of Divx (they gave it away free for 24 hours when 6 was first released) and a quad core machine, Xvid simply doesn't stand up. Visually there is no difference on my 32" screen, and Divx renders in less than half the time.
    Read my blog here.
  4. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    H.264 is awesome but DAMN it is slow ... very slow!
    Having said that it does a much better job than DivX/XviD although I find HD XviD to look really good as well ... much better than the simple profile or Home Theater profile for SD resolutions.
    XVID4PSP has a great HD XviD profile and it is compatible on the Sony PS3 as well as the XboX 360.
    For speed of encoding and image quality I find it looks as nice to my eyes as using H.264 but it doesn't compress as well (much larger file sizes). Well OK maybe I do see the occasional difference with H.264 getting the nod in quality but HD XviD via XVID4PSP looks pretty damn good.
    - John "FulciLives" Coleman
  5. I find Xvid to be slightly better than Divx but the difference isn't really noticeable at normal playback speed. You have to look at enlarged still frames to see the difference. And even then it can be hard to say which is better, just that there are slight differences.
    A the slowest (highest quality) settings the two aren't too different in terms of speed. But at the medium ("Balanced in Divx, General Purpose in Xvid) and fastest settings Divx can be twice as fast as Xvid. The relative difference in speed between the two varies depending on the number of threads/cores used too.
    If you're going to use Xvid and have a multi-core or multi-cpu system be sure to get a multi-threaded build.
    Dec 2004
    Triptonia
    xvid multithreading is fairly limited though,
    don't go in with high expectations
    "I'll give you five dollars if you let me throw a rock at you"
  7. A quick Xvid encode (720x480 DVD MPEG2, 90 seconds, 23.976 fps, MPEG2Source(), VirtualDub, Fast Recompress, Q6600 CPU) with Motion Search Precision and VHQ Mode at the highest (slowest) settings:
    1 thread: 75 seconds
    2 threads: 49 seconds
    4 threads: 36 seconds
    And for a comparision, the same clip with x264vfw at "default" settings:
    1 thread: 139 seconds
    2 threads: 74 seconds
    4 threads: 39 seconds
    Obviously, x264vfw scales much better.
  8. x264 fastest settings for a particular encode are 1.5x the CPU core count. So for a quad it would be 6 threads. Most x264cli GUI's default to that formula when threads are set to "auto". Not sure if this applies for x264vfw, but I would guess it should
    Sometimes the bottleneck for better scaling is avisynth (at least with x264), which may be aleviated by using avisynth mt (but very buggy). Interestingly using a 64-bit OS nets 5-10% faster speed gain with x264 as well
    I'm surprised xvid scaled respectably in your mini-test jagabo. I don't recall it doing so well in my testing. What version is that?
  9. Member yoda313's Avatar
    Jun 2004
    The Animus
    You might also look into wmv for another alternative. Granted it has less overall compatibilty in portable players than either xvid or divx but if you can play it you may like the quality as much or more than either of them.
    There is also the wmv hd variety but I haven't played around with that at all so I can't comment on it personally.
    I use a zune and wmv is just fine. I use corel dvd copy 6 and the standard quality wmv setting. I get good looking 2 hour movies at around 500mbs at 320x240.
  10. Banned
    Nov 2005
    you've already gotten a few responses along with some suggestions for a couple of alternatives to try, allow me to suggest one more, even though it may get me flamed: real media 10.
    i sometimes use it via real producer 11, and i have to say the quality is outstanding and the speed is incredible; on a quad core phenom 9500, with only 80% cpu usage, encoding a 720p ---> 720p at 5000 kbps vbr with 160 kpbs vbr audio, it encodes in faster than real time.
    the only downside is that real's codec is not as widely supported as divx and/or xvid, but then again i would argue that if you want maximum compatibility you should be sticking with h264, as that is the future of video compression.
  11. Originally Posted by poisondeathray
    I ran tests with 6, 8 and 64 threads and got 36 seconds (compared to 39 seconds with 4) for 6 and 8, a second more with 64. Thanks for that info.
    It is XviD-1.2.-127-VAQ.exe from http://www.koepi.info/. I find the scaling varies depending on what settings you are using. Even on what source you are compressing. But I usually see in the range I reported. Going more threads than cores used to lock up Xvid but that seems to have been fixed. Speed still doesn't increase with more threads than cores. And obviously, if you are doing a lot of filtering the compression time becomes a smaller portion of the overall encoding time.
    Mar 2008
    India
    Hmmmmm many replies away from my query...Thanks still
    Dec 2004
    Triptonia
    exactly
  14. Banned
    Jun 2007
    UNREACHABLE
    You should also give a try to VC-1 (the "Hi-Def WMV" that Master Yoda talked about).
    It may look as good as/even better than H264,
    depending on the eye of the beholder of course
    However VC-1 can take ages to encode if your computer is not powerful enough.
    Dec 2004
    Triptonia
    seems your query was answered.
    nothing like testing for yourself.
    midzuki pushing m$?
  16. Banned
    Jun 2007
    UNREACHABLE
    45tripp wrote:
    midzuki pushing m$?
  17. Member vhelp's Avatar
    Mar 2001
    New York
    Morning all.. Ok, ok.. stupid question.. what command line tool can encode to VC-1 format ?
    (there's the "generics" ffmpeg and mencoder for h264, and the better alternative, x264 cli)
    -vhelp 4907
  18. Banned
    Jun 2007
    UNREACHABLE
    Hi there again, Mr. vhelp
    AFAIK, only the damn Windows Media Encoder supports command-line encoding
    (via the WMCmd.vbs script, bien entendu). Not that I've ever tried that ---
    --- I still am quite happy with WMNicEnc
  19. I haven't used this, but avs2asf by Kurtnoise might be what you're looking for
    avs2asf
    http://kurtnoise.free.fr/index.php?dir=misc/
    discussion
    http://forum.doom9.org/showthread.php?t=133173&highlight=avs2asf
    wmvmuxer and WMNicEnc are ok for WVC1 if you can tolerate a GUI
  20. Banned
    Jun 2007
    UNREACHABLE
    Thanks for the update of my KB, Mr. DeathRay
  21. Member vhelp's Avatar
    Mar 2001
    New York
    Thanks for answering my questions, this is great. cant' belive there's still no simple gui for avs2asf, though its a bit confusing to me.. even more so when when a read in the fest few thread (via provided links) about wmv.. should have been avs2vc1. So, who am I ?? .. how am I ?? .. what'tam I.. fooy
    So, perhaps someone will make a non - .NET but win98 friendly gui tool. And now back to our program..
    -vhelp 4910
