I've been using convertxtodvd for a year now and it worked really good and FAST.However,since 2 days ago,the encoding takes too long.This is something unusual as it has been encoding videos really fast.I tried converting other videos just to see if it was the raw video that caused the problem but NO.Convertxtodvd is the one running very slow.Can it be slow because of my computer's memory??Some ppl say that your memory can affect certain programs to run very slow.I think my memory is about 246 MB.
Is there any way to make this software fast again??
Results 1 to 14 of 14
I can't live without my computer.
2048 MB you mean probably.
why don;t you ask VSO for technical support?
open the task manager and keep track of memory usage if you suspect it.
tripp"I'll give you five dollars if you let me throw a rock at you" -
I already checked.My memory is 248 MB.Should I upgrade it to 2 GB??Originally Posted by 45trippI can't live without my computer.
I would at least upgrade it to 512MB, but 1GB would be better. You wouldn't likely see much more improvement going to 2GB with XP. Encoding doesn't really use much RAM, but 248MB is too low and your programs may have to access your hard drive a lot more to make up for a lack of memory. If your hard drive is fragmented, and you have low amounts of RAM, that may slow down some programs.
But I suspect your problems with ConvertX are caused by something else. Maybe some program that's running in the background. Some anti-malware programs can do that. You can check how much RAM is being used, along with how much CPU power is being used with Task Manager. And if you watch your hard drive indicator light and it's constantly lit or flashing all the time, your computer may be accessing the hard drive more than it really needs to.
The only light I can see flashing is the power ON button.Originally Posted by redwudz
Can you tell where I can find that Task Manager?I can't live without my computer. -
Alright,already looked up Task Manager and most of my CPU usage is 00????I don't understand the whole thing but I am pretty sure that my memory is still big.Originally Posted by redwudzI can't live without my computer.
When you have convertxtodvd actually encoding, open the task manager and click on the Processes tab. Click on the heading for the CPU column to sort it by CPU usage. ConvertXtoDVD should be at the top of the list, and should be using most of your CPU. If it isn't then you have something going on that needs checking out.
Click on the Performance tab to see memory usage. Physical Memory and Commit Charge are the two of most interest. If the total commit charge is higher than the total physical memory then you are using the page file extensively, which will also increase the amount of HDD access required (the page file is an area of HDD set aside to act as memory for when you run out). Using the page file is dramatically slow down any functions that require disc access.Read my blog here.
Thanks for the info.So I already did like what you said.My CPU usage constantly changes from 95 to 98 percent and I also checked my memory usage.And yeah,my commit charge is higher than my physical memory.Is that the cause for Convertxtodvd to be running so slow suddenly??But this has never happened beforeOriginally Posted by guns1inger
Like I said,it used to be super fast!
If you are using the page file (which you are - heavily) then you are reading and writing to access the virtual memory, as well as reading and writing the file you are encoding. This will slow you down a lot.
There are a couple of reasons things may have become slow recently.
1. Have you upgraded, added or changed any software that runs resident, such as anti-virus or anti-spyware software ? Have you added VOIP or messenger services ? All of these run resident and use memory. Shutdown everything you can in the tray before running ConvertXtoDVD.
2. Have you upgraded ConvertXtoDVD recently ? I believe that version 3 requires more memory than version 2.
3. When was the last time you defragged your HDD ? A badly fragmented page file will slow your system to a crawl. Try using jkdefrag, and running it at boot up so you can defrag before the page file is built.
4. Finally, check your event logs (right-click My Computer and select Manage) and look for Disk errors. These indicate the you have problems with your HDD, and these errors will also often result in very slow access and overall performance issues.Read my blog here.
In my case,it's not reason no. 1 and not reason no. 2 either.I already checked my event logs and there are no errors regarding convertxtodvd at all.I am not sure about reason no. 3 though.I don't know what defrag means.Do you mean that I have to go to the control panel and click on "performance and maintanence" and then click on "rearrange items on your hard disk to make programs run faster"???Originally Posted by guns1ingerI can't live without my computer.
That is the built in defrag tool, however it is not a very good one. It will do some basic housekeeping, but that is all. If you want your drive properly defragmented, use something better. jkdefrag is small and free and very good at what is does. Auslogics is also free and very good, and probably easier to use : http://www.auslogics.com/en/software/disk-defrag/download
Install a defrag tool. Install CCleaner. Run ccleaner and remove all the crop from your system. Go into the performance settings of My Computer and reduce your page file to 100MB. Reboot your machine, and defragment the HDD. Reset your pagefile to be computer managed, and reboot. See if things run any faster.Read my blog here.
Thanks for recommending me that software.I already run ccleaner and that defrag tool but I haven't tried running convertx yet so I don't know if it is now fast or not.However,in the defrag summary,it says that the speed has increased 8% and there 17620 junk files in my PC.How do I remove these junk files???Is there and freeware that you can suggest?Originally Posted by guns1ingerI can't live without my computer.
I had the exact same problem and the answer was simple, but it took me some time to realize.
The cpu was running very hot, because my cooler was so dusty it wasn't working properly. So my temperature was raising at 70, 75 Celsius when the conversors were running, believe it or not - a very dangerous temperarure, since the normal is 40 C. That had a major impact on conversors, cause they force the processor to work harder than other programs, and the temperature tends to rise anyway... but if your cooler is too weak, it will get way too hot, and these softwares will warn you before any others, although everything is already losing performance.
So, first of all, get some program to check your cpu temperature. I used Everest, but there are others. If the temperature is above 60 Celsius, you have to clean or even change your cooler. It's unexpensive and quick. For an even better performance, add some more fans inside the cabinet.
Hope it helps.
DVD burn runs too hot, how to slow down reading the source disk
By loninappleton in forum DVD RippingReplies: 6Last Post: 28th Apr 2012, 09:31 -
Winavi Runs Slow On Old Computer Any Way To Speed It Up
By DJboutit in forum Video ConversionReplies: 6Last Post: 3rd Jan 2010, 18:36 -
Laptop runs REALLY SLOW!
By Squid_uk in forum ComputerReplies: 22Last Post: 6th Oct 2008, 23:34 -
v2.5.3600 runs very slow and driving me nuts...!!!!
By geek2330 in forum SVCD2DVD & VOB2MPGReplies: 17Last Post: 6th Oct 2008, 10:00 -
video runs slow
By Madgelina in forum EditingReplies: 0Last Post: 8th Feb 2008, 18:45
