Okay. I've run into a pathetic problem here. I just got iMovie '08 and am trying to export this little clip.
This is what I want :
A full quality DV file so I can later convert it into .mov using MPEGStreamclip.
I used to do this in iMovie '06, but I don't want to drag the clips over from '08 to '06 and then export. That is just a retarded, complicated thing to do.
So how can I export from iMovie '08 in full quality?
Thanks.
-I really like iMovie '08. Don't tell me that this stupid little problem will make me go back to iMovie '06.
no hope, you can access to your imovie'08 edit only via its export function (and the export function will remove "high quality")Originally Posted by jooleyen
check your iMovieEvent folder and do (again) the editi in iMovieHD (it will not suppress quality)
I don't think it's a stupid little problem, I think it's the main one!I really like iMovie '08. Don't tell me that this stupid little problem will make me go back to iMovie '06.
iMovie '08 is an ergonomic app, but Apple choose ergonomy versus quality (Video is complex, and interlaced videos -like dv or HD1080i files- must be threat with a lot of attention). Apple chosed to remove quality (suppress half of the information) to make an easy and "funny" app.
Choose what you prefer: ergonomy (iMovie'08 ) or quality (iMovieHD), you can't have both
byeFor DVD, iPad, HD, connected TV, … iMovie & FCPX? MovieConverter-Studio 3 (01/24/2015) - Handle your camcorder's videos? even in 60p or 60i? do a slow-motion? MovieCam.
export from iStopMotion to edit in iMovie 09
By kvdv in forum MacReplies: 19Last Post: 29th Sep 2009, 09:56 -
VOB to MPEG to MOV to export to iMOVIE HD 06 HELP PLEASE!
By HowardNeedsHelp in forum MacReplies: 5Last Post: 16th Aug 2009, 07:15 -
which format should i export my imovie projects to
By Lu-min Chew in forum Video ConversionReplies: 1Last Post: 6th May 2009, 03:18 -
iMovie '08 -- Can't find export to DV camcorder in new menus
By edDV in forum MacReplies: 1Last Post: 11th Feb 2008, 00:44 -
How do I export an iMovie project to DivX?
By tren in forum MacReplies: 8Last Post: 17th Jan 2008, 16:44
