Hi All
Figured it was time for me to try out creating an image file of my hard disk - so I got a trial version of DriveImagePro - it created a 4GB Image file - then I used DriveImagePro to create an .iso file of this image file
I am doing this as a test so I am prepared to reformat my test FAT32 drive - then I want to restore everything the way it was
I figure I need to create a bootable DVD - but how do I go about restoring this image file?
DriveImagePro says that I need to be a registered user in order to be able to use their bootable CD/DVD:
" When you wish to restore a system drive, you must use the O&O DiskImage Start CD and start the restoration from there. "
Is there any other way?
TIA
probably not. you might want to try a free utility.
http://www.thefreecountry.com/utilities/backupandimage.shtml -
Be aware that some imaging software will restore an image to a hard drive of identical size only.
If you are using XP, I'd check out Ultimate Boot CD for Windows. Great tool for disasters and includes a number of free imaging products. -
Thanks for the links - I have looked at these before - I need to fully digest the info re Ultimate Boot CD - hopefully I can figure it out
Can't restore win7 backup image from server with win7 image restore.
By Denvers Dawgs in forum ComputerReplies: 2Last Post: 14th Dec 2010, 19:56 -
Backup image to a restore partition??
By ranchhand in forum ComputerReplies: 13Last Post: 9th Jul 2010, 15:41 -
Restore disk image on different operating system
By r3n4ud in forum ComputerReplies: 7Last Post: 1st Sep 2009, 10:44 -
Burning iso image from Hard disk to hard disk?
By When in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2008, 23:27 -
Restore Ghost Image Problem
By bevills1 in forum ComputerReplies: 3Last Post: 1st Apr 2008, 14:03
