I'm trying to convert a couple of 30 minute videos that are in mp4 format to flv. The problem is that I often have to convert them to avi first then to flv... i've been able to do this with smaller videos but the larger ones only yield about 2-5 mins... is there a limit to the size of a flv file using ffmegx? If so, how can I get around this so I can get these converted? Thanks!
Results 1 to 12 of 12
I just successfully converted a 28 min XviD AVI to FLV, and also an H.264 MP4 to FLV directly. I couldn't reproduce your 2-5 mins issue. I have no idea why it would cause this problem for you.
Perhaps you can give some parameters of this source file. Maybe there are file specific things going on.
Sure! this is the info I get when I try and convert the .mp4 fileOriginally Posted by Case
FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
Mac OSX universal build for ffmpegX
libavutil version: 49.0.0
libavcodec version: 51.9.0
libavformat version: 50.4.0
Thu Oct 2 16:34:17 PDT 2008
Seems that stream 1 comes from film source: 1000.00 (1000/1) -> 30.00 (30/1)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Users/tjfisher/Desktop/chep1.mp4':
Duration: 00:26:40.3, start: 0.000000, bitrate: 547 kb/s
Stream #0.0(eng): Audio: aac, 44100 Hz, stereo
Stream #0.1(eng), 30.00 fps(r): Video: mpeg4, yuv420p, 320x240
Codec type mismatch for mapping #0.0 -> #0.0
This is the info I get after converting the .mp4 to a .avi
Thu Oct 2 16:40:52 PDT 2008
Input #0, avi, from '/Users/tjfisher/Desktop/chep1.avi':
Duration: 00:26:40.3, start: 0.000000, bitrate: 29164 kb/s
Stream #0.0, 30.00 fps(r): Video: dvvideo, yuv411p, 720x480
Stream #0.1: Audio: pcm_s16le, 22050 Hz, mono, 352 kb/s
Output #0, flv, to '/Users/tjfisher/Desktop/chep1.avi.ff.avi.flv':
Stream #0.0, 29.97 fps(c): Video: flv, yuv420p, 320x240, q=2-15, pass 1, 700 kb/s
Stream #0.1: Audio: mp3, 22050 Hz, stereo, 56 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
bench: utime=87.252s
video:33101kB audio:2884kB global headers:0kB muxing overhead 1.250380%
Stream #0.0, 29.97 fps(c): Video: flv, yuv420p, 320x240, q=2-15, pass 2, 700 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
video:33190kB audio:2884kB global headers:0kB muxing overhead 1.247273%
bench: utime=87.493s
/Users/tjfisher/Desktop/ffmpegX_0.0.9y/ffmpegX.app//Contents/Resources/flvtool2:2:in `require': no such file to load -- flvtool2 (LoadError)
from /Users/tjfisher/Desktop/ffmpegX_0.0.9y/ffmpegX.app//Contents/Resources/flvtool2:2
In your .mp4 file the audio stream is listed before the video stream. This is reverse from how ffmpeg handles conversion by default. For other types of conversions, I would recommend the "Invert mapping" setting in the Audio tab, but for conversions to FLV this setting would introduce a stuttering issue with Adobe Flash Player (the webbrowser plug-in) that you wouldn't want.Originally Posted by graphictodd
You can invert the streams using QuickTime Pro, before conversion, as a work-around.
This seems like two encodings?!? Did ffmpegX do this by itself, or did you paste two logs here? No apparent errors in there, besides the non-fatal one below.Originally Posted by graphictodd
Apparently you do not have flvtool2 installed, which prevents ffmpegX to add metadata (such as duration) to the FLV clip. It shouldn't effect the FLV video quality itself, nor playback.Originally Posted by graphictodd
That is weird audio for a DV file. DV usually has 2 channels at 48000 Hz and 1411 kbps. Not sure if it influences conversions, though.Originally Posted by graphictodd
Thank you so much for you excellent reply!Originally Posted by Case
How would I invert them in QT pro?
And yes, both those log files were created by ffmpgx. I'm going to download flvtool2... i've been transferring my converted .flv files on a thumb drive then putting them on a PC and using a meta inject for years now... I had no Idea this flvtool2 was available! Thank you!
The line "You can invert the streams using QuickTime Pro, before conversion, as a work-around"Originally Posted by graphictodd
is actually a link to an older post on this forum, describing how to do it.
In more detail:
1/ Download "flvtool2-1.0.6.tgz"
2/ Decompress "flvtool2-1.0.6.tgz" into "flvtool2-1.0.6.tar" (normally Safari does this for you)
3/ Decompress "flvtool2-1.0.6.tar" into folder "flvtool2-1.0.6"
4/ Open Terminal.app
5/ Type "cd " (without the quotes, including the space character)
6/ Drop the folder "flvtool2-1.0.6" onto the terminal shell window
7/ Make sure the Terminal window is still active (frontmost), then press the <enter> (or <return>) key
This should change the working directory to the "flvtool2-1.0.6" folder
You can verify this by looking at the prompt: Computer-name:/working-directory/ username$
8/ Type "ruby setup.rb config" (without the quotes), followed by the <enter> key
You should get a few lines of output with arrows (--->)
9/ Type "ruby setup.rb setup" (without the quotes), followed by the <enter> key
10/ Type "sudo ruby setup.rb install" (without the quotes), followed by the <enter> key
This will require that you enter your login password
You should get more lines of output, many of them starting with "install"
Thank you Case... I Followed your directions to a "T" here is what my terminal window says...Originally Posted by Case
Last login: Wed Oct 8 09:58:47 on ttys000
t-f-macbook:~ tjfisher$ cd
t-f-macbook:~ tjfisher$ /Users/tjfisher/Desktop/flvtool2-1.0.6
-bash: /Users/tjfisher/Desktop/flvtool2-1.0.6: is a directory
t-f-macbook:~ tjfisher$ ruby setup.rb config
ruby: No such file or directory -- setup.rb (LoadError)
help!
I can't be this stupid!
How to record streaming flash video, edit and save as AVI, MP4, FLV,etc.
By Baldrick in forum User guidesReplies: 3Last Post: 20th Sep 2014, 14:06 -
rm/flv/mp4/wma/3pg/avi Convertor
By toqi786 in forum Video ConversionReplies: 2Last Post: 14th Jul 2009, 06:57 -
Having trouble with a conversion (mp4 / avi / mov / flv)
By loxley in forum Video ConversionReplies: 4Last Post: 23rd Feb 2009, 11:17 -
Best way for converting VOB to FLV, AVI, MP4
By lana2000 in forum Video ConversionReplies: 13Last Post: 22nd Feb 2009, 09:56 -
Should I convert .flv files to .avi or .mp4?
By johnharlin in forum Newbie / General discussionsReplies: 6Last Post: 1st Dec 2008, 13:51
