Hi if anyone can tell me , can you capture at higher resolution than
studio7 provides (pal 360x288) .also cannot seem to capture with ulead or virtual dub
thanks in advance :D
I just took back my DC10+ card yesterday for the simple fact that it would not use anyone elses compression but their own. Virtual Dub see's it and uses it and actually made pretty darn decent captures (using their codec only) but when it came to converting to mpg1/2 using Tmpegec, it would never convert the video, it would convert the audio only. If you used avi2vcd it would convert the video upside down. I just had to take it back and get something else.
I own two of these cards (for different computers) and I love them. I capture at 640x480 (using the VidCap program in the folder) and have NEVER had a problem encoding to mpg1 or 2 with TMPGenc.
I really only capture ith this program, not even the pinnacle program it came with(It sucks).
I've not had a problem with only the audio encoding, or upside down or anything like that."I think I know exactly what I mean, when I say it's a Shpadoinkle day!" -
thanks for the replys guy, but mijman what folder and how do you set the rstolution to what you said - sorry for being a pain :-?
Problems with Pinnacle Studio 9 using DC10+ Capture Card
By alexh110 in forum Capturing and VCRReplies: 0Last Post: 29th Jul 2011, 04:03 -
Software for S-video output on Pinnacle DC10 plus card(XP)
By Eightbitgnosis in forum Software PlayingReplies: 2Last Post: 30th Jan 2010, 10:33 -
GEEKS! I just bought the Canopus ADVC-300 and I need your input and advice!
By _yo_wasup_ in forum Capturing and VCRReplies: 22Last Post: 3rd Jul 2009, 17:49 -
Pinnacle AV/DV2 or DC10+B miserable performance
By cybertheque in forum Capturing and VCRReplies: 1Last Post: 17th Sep 2008, 22:44 -
Pinnacle DC10 Plus on Windows XP
By Paulsa in forum Capturing and VCRReplies: 0Last Post: 3rd Apr 2008, 11:02
