I have a 30 minute MPG. When I play the file, my computer acts like it's 30 seconds long. The file plays and the video bar moves across for 30 seconds... then sits at the end as the rest of the video play. And the most interesting part is... if I move the location bar to the middle, the video will play from the 15 minute mark.
It's only this MPG (that I downloaded, not captured and converted) that has this problem. I've tried using the MPEG fixer from the tools section, no use. I've tried seperating the video and audio, and putting them back together... and that doesn't work. It only saves the first 30 seconds. I've tried loading it into VirtualDub and converting it... doesn't work, only saves the first 30 seconds again.
What else can I do to fix this MPG file? If it's the MPG Header that's damaged, is there a real way to repair this to keep track of all the video? I know it's all there because I can watch it all.
Results 1 to 1 of 1
Only rendering the first 10 seconds of a 20 minute clip in After Effects?
By kingmustard123 in forum EditingReplies: 4Last Post: 21st Oct 2017, 09:23 -
delete sound between x seconds and y seconds?
By charlieship in forum Newbie / General discussionsReplies: 3Last Post: 4th Jun 2011, 22:14 -
.mpg file suddenly missing first 30 seconds.
By John97 in forum Newbie / General discussionsReplies: 1Last Post: 18th Nov 2010, 15:17 -
Video only playing 3 seconds .mpg
By richardos in forum Software PlayingReplies: 8Last Post: 20th Oct 2010, 19:27 -
Burned DVD with my comp = won't play, gf's comp = plays perfectly!
By DVDFuzz in forum Authoring (DVD)Replies: 13Last Post: 16th Sep 2010, 05:39
