  1. When opening mpeg 2 files I notice under "sequence display extension" nothing is there. I believe it should show 720 x 480. This is true even after authoring the files. The mpeg 2 files are TV caps create with Ulead and my Hauppauge card. I use TDA to author.
    Dec 2004
    Triptonia
    you certainly don't need it.
    only seen it once, for 2:35, where it has valid use.
    the flag is also likely to cause problems.
    also if it's set to the same as the actual resolution it has null effect,
    so having it empty is better.
    also,
    tda sucks!!
    tripp
    "I'll give you five dollars if you let me throw a rock at you"
