Ok, so this is my first post here, though I've always been able to find the answer by just being a lurker and doing enough searches here, you guys are all great and knowledgeable!
So, I have a 7.75GB HD Movie in .WMV format with a resolution of 1920x816, bitrate 10200kbps, and FPS of 25. The audio is 5.1 with 384kbps.
I am trying to create a really HIGH quality iPod video conversion for personal use only, since the files will be way too large for anyone else to want :P
Personally, I love using both Videora & SUPER for iPod conversions, and I'm fairly competent using Videora as a power user and editing the conversion profiles to fit my needs, but I can't seem to get past the problem of the 5.1 Sound and ffmpeg having issues with that sound format.
So here is what I would love (but I'll take any help you can give me):
1) Help getting Videora to convert the file, because then I know I can get the settings just right for how I want the file converted. ... or ...
2) Help converting the WMV file so no video quality or audio quality is lost, though the audio is converted to a much more simple Stereo 2-Channel audio.
With any help you give me, please try to be specific so I can follow along ... and any programs you refer me to get, please either provide a link or tell me where I can get it.
Thanks ahead of time!
Results 1 to 11 of 11
You could try frameserve using avisynth, install avisynth, open notepad and type
Directshowsource("c:\folder\video.wmv")
Replace the c:\folder\video.wmv" with the location of your video file and save it as video.avs (be sure change to save file type: All files(*.*)).
Open the video.avs in Videora. See http://www.redkawa.com/forums/showthread.php?t=480
Or try convert to ipod using xvid4psp, load the wmv, choose the ipod profile, convert. -
Actually ... I found XviD4PSP while waiting for a response and at first I thought it might not really accomplish what I wanted, but I found how to change more of the settings ... very nice program!!
If this works without any Audio-Sync issues, I may have to bear the creator's children ... lol
Thanks for the reply though, and anyone else with any suggestions, they are most welcome! -
Hrm ... ok, so I got this error with XviD4PSP ... if anyone can help ... please do!
PLATFORM
OS: Microsoft Windows NT 6.0.6001 Service Pack 1
OEMCodePage: 437
Language: ENU
DecimalSeparator: .
Framework: 2.0.50727.1434
Processors: 2
Machine: ---
UserName: ---
SystemDrive: C:
XVID4PSP
Version: 5.035
Created: 9/23/2008 3:20:34 PM
TempPath: D:\!! Converted !!\XviD4PSP Output
AppPath: C:\Program Files\Winnydows\XviD4PSP5
FILES
Return J.wmv >
Return J.mp4
TASK
Format: MP4 iPhone or Touch
Duration: 02:09:13:400 (193835)
VideoDecoder: DirectShowSource
Resolution: 1920x816 > 640x272
VCodecPreset: Star Wars Custom 1500kbps
VEncodingMode: ThreePass
VideoCodec: VC1 > x264
VideoBitrate: 8416 > 1500
Quality: 0.215 > 0.345
Framerate: 25.000
SourceType: PROGRESSIVE
FieldOrder: UNKNOWN
AudioDecoder: 0
AEncodingPreset: AAC-LC ABR 160k Custom
AudioCodec: WMA > AAC
AudioBitrate: 384 > 160
Samplerate: 48000
Channels: 6 > 2
UpDownMix: ConvertToDolbyProLogicII
Normalize: 100%
Accurate: 3%
Gain: 14.045
VIDEO ENCODING
Encoding video to: D:\!! Converted !!\XviD4PSP Output\0001.264
x264 1500kbps 640x272 25.000fps (193835 frames)
...first pass...
x264 [info]: cabac=0 ref=6 deblock=1:0:0 analyse=0x1:0 me=dia subme=1 psy_rd=0.0:0.0 brdo=0 mixed_ref=1 me_range=16 chroma_me=1 trellis=0 8x8dct=0 cqm=0 deadzone=21,11 chroma_qp_offset=0 threads=2 nr=0 decimate=1 mbaff=0 bframes=0 keyint=250 keyint_min=25 scenecut=40(pre) rc=abr bitrate=1500 ratetol=1.0 qcomp=0.60 qpmin=10 qpmax=51 qpstep=4 ip_ratio=1.40 aq=1:1.00
x264 [info]: slice I:2110 Avg QP:15.22 size: 31095
x264 [info]: slice P:191725 Avg QP:16.92 size: 7277
x264 [info]: mb I I16..4: 16.8% 0.0% 83.2%
x264 [info]: mb P I16..4: 6.1% 0.0% 0.0% P16..4: 79.8% 0.0% 0.0% 0.0% 0.0% skip:14.2%
x264 [info]: final ratefactor: 20.00
x264 [info]: ref P L0 74.7% 10.7% 6.2% 3.3% 2.7% 2.5%
x264 [info]: kb/s:1507.3
...second pass...
...last pass...
x264 [info]: using cpu capabilities: MMX2 SSE2Slow
x264 [info]: cabac=0 ref=6 deblock=1:0:0 analyse=0x1:0x131 me=esa subme=7 psy_rd=1.0:0.0 brdo=0 mixed_ref=1 me_range=16 chroma_me=1 trellis=0 8x8dct=0 cqm=0 deadzone=21,11 chroma_qp_offset=-2 threads=2 nr=0 decimate=1 mbaff=0 bframes=0 keyint=250 keyint_min=25 scenecut=40(pre) rc=2pass bitrate=1500 ratetol=1.0 qcomp=0.60 qpmin=10 qpmax=51 qpstep=4 cplxblur=20.0 qblur=0.5 ip_ratio=1.40 aq=1:1.00
x264 [error]: b_adapt method specified in stats file not valid
x264 [error]: x264_encoder_open failed
? Help Please ? -
Alright ... I'll try that, but won't I lose Quality that way? I'd prefer to get the highest quality conversion possible @1500kbps 640x272 ...
I'll try that in the mean time though
Thanks again for all your help Baldrick! -
2-pass is better yes but I just want to know if you get an error with 1-pass also.
The "b_adapt method specified in stats file not valid"-error doesn't say much....and a google search doesn't give much info. -
I did a quicker 768kbps 640x272 conversion on 1-Pass ... looks good, no audio-sync issues ...
I'll try a two-pass later at a higher bitrate ... but I think you've helped me with an issue I thought I'd never solve ... and I've found a very cool new toy!
XviD4PSP is pretty cool so far ... I'll really have to test it out a bit more though, but so far so good ...
ONE Question though ... how can I get XviD4PSP to do a shortened ENCODE ... for instance, in Videora, I can set the Encoding Duration to a number of seconds which gives me a nice short test of a particular video to encode and I can usually tell if there will be any audio/video issues ...
Can I make a "testing" profile or do something like this in XviD4PSP? -
I love XVID4PSP but I almost always do 1-pass quantizer type encodes with it yet one time (and so far only this once) I tried a 2-pass encode (setting it to a specific file size output) and it finished without any errors listed in the log screen but my A/V file stopped at around 1 hour 20 minutes on a movie that was about 1 hour 59 minutes.
I could never figure out why it did that ...
Any ideas for my question though ... I really can't figure out how to do this ... and maybe it's just something I'll have to suggest for a possible feature to add to the program ...
EDIT: One possibility ... is it possible to add a duration to the AVISynth scripting which is conveniently available to the user prior to starting the encoding process? I'm guessing this is how I can accomplish this, but I just don't know how to do it ... lolOriginally Posted by VixenofVenus -
Trim(0,1500)
Add something like that to the end of the AviSynth script.
The example above will encode from the very first frame to frame 1500 which is about 1 minute.
Trim(0,3000)
This would be 2 minutes.
Trim(0,4500)
This would be 3 minutes and so on ...
By the way the encoder will give you a time estimate based on the full running time of the source file but when it gets to the end frame indicated in the AviSynth script it will end. I just tested it.
- John "FulciLives" Coleman
P.S.
Attached is a MP4 file using the Trim(0,1500) at the end of the script. It was encoded using XVID4PSP v5.035 using the MP4 iPhone/iTouch profile.
trueblood.mp4"The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
Ripbot264 iPod format will play on iTunes but won't sync to iPod/iTouch?
By Riley007 in forum Blu-ray RippingReplies: 2Last Post: 31st Dec 2010, 00:04 -
Unable to convert some WMV files to Ipod Touch format - Why?
By tradertt in forum Video ConversionReplies: 14Last Post: 8th Oct 2009, 04:22 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 09:15 -
DVD to ipod Conversion Problem
By Cirone328 in forum Newbie / General discussionsReplies: 1Last Post: 19th Jul 2008, 11:29 -
Sound problems with h264 (iPod conversion)
By hackwojr in forum ffmpegX general discussionReplies: 17Last Post: 15th Jul 2007, 20:45
