    Jul 2001
    One Step From Hell
    As of late my computer keeps locking-up when I encode a video(DivX to Mpg with TMPEG).
    This is the only time it locks, doesnt lock when I de-multimlex(TMPEG),doesnt lock when I multiplex/cut(bbmpeg). Only when I encode.
    Any idea what I can do to track down this problem???
    Thanx
    Amd Duron 800mhz
    512mb pc133
    32mb video
    etc etc etc
    Feb 2002
    San Antonio, TX
    Read this post and tell me if this helps.
    http://www.vcdhelp.com/phpBB/viewtopic.php?t=78800
    Jul 2001
    One Step From Hell
    Thanx but its my computer thats freezing, like to mouse...cant ctrl+alt+del
    Have to reboot
  4. Try disabling ACPI (power management) and screen savers when you are encoding. I used to have some problems like that too and found that this helped. Just turn off your screen and walk away.
    It would not happen when muxing/demuxing/cutting due to the fact that encoding is a much longer process.
