Dear all,
I have a Quicktime problem. When I play my MPEG-4 Movies, there is a white stripe
going straight diagonally through the Quicktime Window.
This happens after I installed some update or codecs.
I installed some new MPEG-4 codecs into ~/Library/Quicktime,
but nothing happened.
What can I do? I have to do a presentation soon where I show a movie!
With VLC the movie is totally messed up. DIVX Player shows the same
white stripe as Quicktime.
Thanks!
Andreas
Hello,
Can you upload the file here:
http://idisk.mac.com/getclockworks-Public/
I'll take a look at it.
Regards, BJ
http://aeroquartet.com -
Hello,
I've seen the file, no issue for me.
I'm using latest version of QuickTime, with Perian codec (to decode DivX).
http://perian.org
Make sure you remove the other DivX codecs from the /Library/QuickTime/ folder, and keep only Perian.
Regards, BJ
Quicktime codec problem?????
By Riversound in forum Software PlayingReplies: 8Last Post: 5th Jul 2012, 18:22 -
Problem with QuickTime - DV Format
By parisisal in forum Software PlayingReplies: 3Last Post: 10th Mar 2009, 09:56 -
problem with conversion from quicktime to h.264.
By savvyguy in forum Video ConversionReplies: 23Last Post: 19th Jan 2009, 20:49 -
Quicktime Problem: Playing and Exporting
By hzgg2 in forum Video Streaming DownloadingReplies: 1Last Post: 20th Jul 2008, 15:48 -
quicktime movie quality problem
By photofun in forum MacReplies: 10Last Post: 17th Dec 2007, 03:14
