I have a monitor that has a VGA port, however, it also has a HDMI port. Is it possible to have a way that the VGA lead somehow gets changed into HDMI? The reason being that the output of my arcade machine is 4:3 and it wont auto adjust and stretch the image to widescreen.
thanks,
Barry
Does your arcade machine have an HDMI output? VGA is an analog signal and HDMI is a digital one, the two don't mix. DVI has pins to carry the analog signal, that's why you can use a DVI to VGA adapter with it.
Not all DVI connectors have analog available. http://en.wikipedia.org/wiki/Digital_Visual_Interface You can get cables that will output the VGA signal from the correct type of DVI connector, or you can get a DVI to HDMI cable if your box has a DVI output. The formats you will have available depend on the box and the displays settings.
What is the arcade game and what output connections are available?Originally Posted by BReeve
What are the output settings available in the menus?Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
its a jamma board with 1000 games on it.its basically a pc but it boots into the arcade program.its got a normal motherboard with vga, usb, sound output etc.
so you think a vga to dvi will display the picture stretched? -
Such monitors usually accept only DVI-D on the HDMI port. Your game only outputs analog VGA.Originally Posted by BReeve
If your monitor won't manual H-Size adjust for a 4:3 VGA input (which I doubt), you are out of luck.
If you want something that will auto adjust aspect ratio, then you need to replace the monitor with an LCD-TV but test the TV before you buy.Recommends: Kiva.org - Loans that change lives.
You can try this,but little expensive
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3941015&CatId=467
Can I interface my VGA monitor through a HDMI-DVI-D cable via DVI-D to VGA?
By vinny88 in forum Authoring (DVD)Replies: 4Last Post: 14th Oct 2011, 08:31 -
HDMI/VGA/S-Video
By jspall in forum Media Center PC / MediaCentersReplies: 3Last Post: 14th Oct 2010, 15:28 -
HDMI to VGA
By seekerr10 in forum Newbie / General discussionsReplies: 3Last Post: 17th Sep 2009, 03:12 -
VGA to HDMI
By xXFRESHXx in forum ComputerReplies: 4Last Post: 1st May 2008, 13:54 -
HDMI or VGA
By WildParadise in forum Media Center PC / MediaCentersReplies: 19Last Post: 29th Apr 2008, 20:16
