Hi Everyone,
Can any member advise if they have seen PS2 switch that is connected to 2 computers and 1 monitor. With a switch to select which K/M is to be used to input to the monitor.
Difficult to explain, I hope someone knows what I am trying to explain. I have 2 PCs and a dual input monitor and have a wireless keyboard and mouse. I want to be able to select input from either computer to the monitor. It may not exist ..but.. I have to ask.
Any advise appreciated.
i think what you are looking for is called a kvm switch. something like these maybe?
http://www.newegg.com/store/SubCategory.aspx?SubCategory=143&Tpk=kVM%20switch -
They are only available in just about every electronics store I have ever been in. Several manufacturers, options for USB, Audio, Physical switch or keyboard controlled. Should be about US$40.00 for the basic unit.
You may experience issues with the wireless units failing to recognize after switching. Usually works OK. -
Thanks for taking time out to help. The IOGEAR GCS62 2-Port PS/2 KVM switch with built-in cables might be OK, however, I do not need the video connection as the monitor I am using is dual input.
I goofed .... my k/m are infa-red NOT wireless. What I need is a devise to connect my infa-red k/m with 2xPS2 connections to 2PCs with a switch to select the PC of choice.
My monitor won't switch from vga to dvi?!
By fran-man56 in forum ComputerReplies: 12Last Post: 5th Apr 2012, 00:08 -
LCD Monitor I can play my PS2 on?
By oroboro in forum DVB / IPTVReplies: 3Last Post: 22nd Apr 2008, 09:54 -
PS/2 or USB for mouse & keyboard?
By Xylob the Destroyer in forum ComputerReplies: 11Last Post: 9th Feb 2008, 11:23 -
Mouse clicking out of control?
By aelfheah in forum Newbie / General discussionsReplies: 2Last Post: 25th Sep 2007, 18:26 -
_Playing PS2 on widescreen monitor
By sirshafty in forum Capturing and VCRReplies: 4Last Post: 24th Aug 2007, 07:58
