Hi All,
This overflow problem manifested in MuxMan.
From other posts containing text like
it's clear that the combined bitrate at that point was illegal.P-STD buffer underflow by 19582 bytes at 49132892, sector 234862
Firstly, how do I relate those values to a point in time in the video, to get some idea of what kind of material is causing the problem?
Secondly, how do I calculate a safe bitrate?
Is it possible to use the above "by ... bytes" value to calculate by how much the current bitrate needs to be reduced?
And/or, can the safe bitrate be calculated from the specifications? https://www.videohelp.com/dvd says (for PAL video):
I now what my audio bitrate is, I know the current video bitrate, but how does one determine a subtitle stream's bitrate? This particular DVD title has 3 subtitle streams.Total bitrate including video, audio and subs can be max 10.08 Mbps (10080 kbps)
<edit>
Sorry, let me just explain why I need to calculate a suitable bitrate. Obviously I want to use the maximum possible, but I don't want to keep retrying until I get it right - this video takes about 8 hours to encode on my computer! If I could locate the offending footage by the values given in this underflow message I could maybe make a short test clip for experimenting. Otherwise I must be able to calculate the correct bitrate value.
</edit>
Thanks in advance,
Francois
Not that easy...
What kind of subtitle format are we talking about? If it is SUP, you can calculate an average bitrate just with dividing the size (in bit) by the length (in seconds). But there can be parts with a much higher bitrate as the average...
In theory yes, but I don't know how to calculate it either. The "by ... bytes" value is referring to the actual video buffer, and therefore not simply convertible to something like bps.Is it possible to use the above "by ... bytes" value to calculate by how much the current bitrate needs to be reduced?
I would use the max. number of possible chapters (99) spread over the video and check in which chapter the overflow arises...Firstly, how do I relate those values to a point in time in the video, to get some idea of what kind of material is causing the problem?GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
Hello borax,
Regarding locating the offending point in the video:
Towards the end of the log file MuxMan prints (this is not from the same footage as in the original posting):
Assuming that sectors progress linearly, from the Sectors value I calculated average sectors/s over the video and then converted the sector values in the error messages to seconds. These time values were accurate enough when compared to encoder results (see below) as well as the results of Bitrate Viewer.Bitrate - avg: 6959069, min: 655360 (lba 30627), max: 11141120 (lba 23884).
Shortest GOP has 2 fields, longest GOP has 30 fields.
Fields: 5950, VOBU: 208, Sectors: 50545.
Judging by their values, the "lba" values probably also refer to sectors.
Regarding calculating a safe birate:
I am still unable to use the values MuxMan printed to calculate a safe bitrate, but an additional dimension to the problem just emerged. MEncoder sometimes violates its maximum bitrate setting, probably causing this MuxMan behaviour.
When preparing the encode that leads to this muxer failure, MEncoder reports e.g.
BUFFER UNDEFLOW at stream 0, raising muxrate to 11088 kb/s
That whilst vrc_maxrate=9800 on the command line.
I've asked the MEncoder-users mailing list for advice and will see what happens.
Hopefully if I can disappear that problem it will disappear MuxMan's P-STD buffer underflow problem
Failing a fix via MEncoder, what excellent, rock-solid and free alternative to MEncoder would you recommend?
Kind regards,
Francois -
Hank's encoder: HCenc
GUI for dvdauthor:
Because I'd invested so much effort timing subtitles etc. I wasn't keen to edit out the problem footage and re-encode and re-time subtitles. Similarly I wasn't keen to get to grips with a new encoder and run lots of test encodes to get to its best settings for particular footage etc.
So luckily I found an older encode which isn't quite ultimate quality but which doesn't cause the problem
I'll keep HcEnc (and ffmpeg) in my back pocket in case
Email me your postal address - my first DVD is now completed, and beautiful!
MuxMan : Buffer Underflow
By Bonie81 in forum Authoring (DVD)Replies: 3Last Post: 23rd Oct 2011, 15:38 -
How do I calculate bitrate for 320x240 .m4v?
By dave692 in forum DVD RippingReplies: 1Last Post: 5th Aug 2011, 16:31 -
ffmpeg gives buffer underflow
By zkab in forum Video ConversionReplies: 2Last Post: 9th Aug 2010, 03:45 -
How do i calculate the correct bitrate for Xvid codec?
By Ingolf in forum Newbie / General discussionsReplies: 4Last Post: 9th Jan 2009, 09:32 -
DVDFab not outputing the correct bitrate
By David97 in forum Newbie / General discussionsReplies: 5Last Post: 9th Feb 2008, 15:08
