I know that you can buy DVD movies that also include a bit of software. (You put the DVD in your computer to take advantage of the software). My question is: How can I also include software on the DVD? It was suggested to use ImgBurn. "Use build mode. Put your Video_TS and Audio_TS in the build box. Then insert any other files in the build box that you want on the disc. Then burn it to a DVD."
However, I want to try to use Nero 6 to do this. Does anybody know if Nero can do this?
dvds are a data disc. if nero can burn a dvd data disc in iso/udf bridge format than yes. but that begs the question of why you would not use imgburn as it's light years better at burning anything than nero and it's free.
i'm not sure that nero 6 could burn dvds at all, it's too old. iirc v6.6 added dvd burning.
Bluray to dvd ( include menus )
By pcb in forum Blu-ray RippingReplies: 7Last Post: 26th Apr 2010, 20:35 -
Samsung BP3600 problem playing Nero authored DVD's
By stonejg in forum DVD & Blu-ray PlayersReplies: 6Last Post: 10th Jan 2010, 12:56 -
Question about how to include software on authored DVD
By jimdagys in forum Authoring (DVD)Replies: 2Last Post: 28th Sep 2008, 19:47 -
How do I include wmv to a dvd with mpeg2?
By Jensen in forum Authoring (DVD)Replies: 6Last Post: 4th Jun 2008, 20:50 -
Software to make sure the audio and video of a authored dvd are in sync?
By snafubaby in forum Authoring (DVD)Replies: 7Last Post: 1st Oct 2007, 07:13
