Beginners question...How can I burn my Hi8 to DVD with the same analogue quality using my pc? I capture it using Nero and Windows Movie Maker...but to get high quality video it needs a very large space...about 20+GB. When I burn it to DVD, it fit the DVD space but give a low video quality...
What setting do I have to change?
I'm using Sony DCR-TRV250E PAL
My pc Intel(R) Pentium(R) D CPU 2.66GHz 2.67GHz, 992MB RAM
I guess you are using nero vision to convert to DVD? Try something else to convert the DV to DVD, like tmpgenc dvd author 3, ulead videostudio or free encoders like hc encoder. And don't try to squeeze in too many minutes/DVD.
I have a bunch of old Hi8 tapes that I REALLY want to digitize, in the highest quality possible. What kind of hardware is required to transfer the video from our old, semi-functional(the viewfinder doesn't work, but it will still play on a TV) Hi8 camcorder to my computer? We have a Samsung VCR to DVD recorder(Samsung DVD VR357)https://www.videohelp.com/dvdrecorders/samsung-dvd-vr375/2414#comments, would that work, and if so, how would I go about doing that? It mentions DV/D8 dubbing in the manual. but I think that's different(digital vs. analogue)? If I can get it to a DVD, then I can get it to my computer(DVDShrink), but I just don't know how to convert it to any digital format.
Fight overpopulation, eat babies :spell: -
Several ways to cap Hi8.
1. DVD Recorder: Connect S-Video and audio to inputs and record in high quality (1hr) mode for good quality. 2hr mode (~4 Mb/s) has inadequate quality for shaky hand held video.
2. Capture to any computer capture device using S-Video and audio connection. Again encode at high bit rate for high quality.
3. Play back in a Digital8* camcorder and capture over Firewire (IEEE-1394) as DV format. Then edit DV and Author DVD.
4. Capture S-Video and audio to a MiniDV camcorder with analog-pass-through feature. The signal will be passed to the computer over the Firewire connection.
* Not all Digital8 camcorders play Hi8. Check manual.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Sony Hi8 has been defective but want to play the Hi8 tape
By coody in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 22nd May 2009, 22:06 -
hi8 TO DVD VIA i.link interface
By ACKEE in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 30th Oct 2008, 08:11 -
hi8 to dvd
By jmoore_cne in forum Newbie / General discussionsReplies: 6Last Post: 3rd Jun 2008, 13:45 -
Hi8 vcr, better playback than a Hi8 camcorder?
By Knightmessenger in forum Capturing and VCRReplies: 8Last Post: 22nd Dec 2007, 01:11 -
Will cheap new Hi8 camcorder output better than old, worn Hi8 camcorder?
By ErikL7 in forum RestorationReplies: 7Last Post: 2nd Sep 2007, 06:26
