I want to use VirtualDub to convert a 4:3 letterboxed MPG file to a 700MB or thereabouts DIVX AVI. I've already demuxed the audio and video and have created an avs file with the cropping, deinterlacing, and fps instructions. I was just looking through the options in the Divx codec through VirtualDub's configurations and I see that there is a cropping utility there as well. I just wanted to know if I would get faster conversion results if I imported the video as an avs "pre-cropped" (I add the mp3 of the audio using "audio from other file") or to crop with DivX's configurations? I'm thinking its the former but I thought I'd ask.
test it
let us know"I'll give you five dollars if you let me throw a rock at you" -
As a general rule, processing through avisynth is faster than processing through virtualdub unless using only virtualdub filters and therefore working in RGB space. That said, the overhead of cropping is so low that the difference will probably be minimal ( < 5%). If you are working with avisynth specific versions of virtualdub filters for things like noise reduction and deinterlacing you can see savings of 20 - 30%, and sometimes orders of magnitude difference.
Read my blog here.
Do it in the AviSynth AVS script.
Cropping Question
By darkdream787 in forum DVD RippingReplies: 25Last Post: 27th Oct 2011, 18:07 -
DVD->DIVX using Xvid4PSP: Aspect/cropping issue
By thomas_fogh in forum Video ConversionReplies: 7Last Post: 5th Oct 2008, 16:37 -
Cropping in Divx Convertor or Divx Author???
By rahul.never2far in forum EditingReplies: 9Last Post: 25th Sep 2007, 11:28 -
Cropping Question
By cowboysroy31 in forum EditingReplies: 2Last Post: 15th Aug 2007, 21:41 -
Cropping a divX encoded movie
By big_uk_ebuyer in forum EditingReplies: 4Last Post: 10th Jun 2007, 22:29
