Hi all,
I have used Windows XP, Acer laptop, FireWire 1394, windows movie maker to capture my film from a little handy cam (sony Digital handy cam) and I converted it to DVDR by using Nero 7.
The problem is when i watch it in my DVD player it has every bad quality. why?
Thanks for your response.
Use instead WinDV to capture the dv stream(Or capture in Windows Movie Maker and export as DV, not WMV).
Convert it to dvd using nerovision...or I would try another all-in-one converter like tmpgenc dvd author 3 or if you don't need fancy menus you can use free tools like dvd flick, favc.
Capturing DV without Firewire
By indijay in forum Capturing and VCRReplies: 8Last Post: 4th Dec 2011, 09:41 -
Bad quality WMV - will a conversion increase quality?
By nickbrace in forum Video ConversionReplies: 4Last Post: 20th Oct 2011, 04:48 -
Help Capturing DV, no Firewire
By fozzieb in forum Capturing and VCRReplies: 5Last Post: 6th Jul 2010, 13:07 -
R there good and bad firewire PCI cards??
By sdsumike619 in forum Capturing and VCRReplies: 3Last Post: 3rd May 2008, 15:25 -
Motion Blur/Bad Quality when capturing uncompressed
By Ezekiel 4:12 in forum Capturing and VCRReplies: 4Last Post: 15th Jul 2007, 01:44
