Newegg has the CM 590 case on sale for $39.99 after using a promo code. If I was to purchase 2 of those cases would I be able to get $20.00 off each case? Any comments will be appreciated! Thanks!
I've never liked cases with the PSU on the bottom
The best way to find out is to put 2 in the shopping cart and add the promo code - then see what discount it gives you.
Stiltman has a good point - If the power supply is on the bottom, then all the heat from it will fill the case - hot air rises ."I will not be pushed, filed, stamped, indexed, briefed, debriefed, or numbered! My life is my own" - the Prisoner
(NO MAN IS JUST A NUMBER)
be seeing you ( RIP Patrick McGoohan ) -
[s:06ce06ccbf]no, you can only get $20 off one case if you buy two.[/s:06ce06ccbf] mabey
Usually you can only use one promo code per item/purchase/receipt (newsletter promo codes)
[edit: I suppose it depends where the promo code came from, and the specific terms tied to it. ]Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think. -
Thanks for the replies. I did contact Newegg and it's only one per account. I got the CM 590 case on Friday afternoon. It now houses my Intel Conroe E6400 2.13ghz cpu that's overclocked to 3.20ghz using a Enzotech Extreme X heatsink & Scythe S-Flex F fan. I actually prefer the psu on the bottom since heat rises and the CM 590 has two top exhaust fans. This case has good airflow with my cpu temps at 34c loaded, video encoding w/dvdrb pro 38c and system temps 40c. I also have the CM 690 which houses my Intel Wolfdale E8400 cpu that's overclocked to 3.60ghz. These CM cases have lots of room, good airflow and cables can be hidden behind mobo for good cable management.
How To deinterlace IVTC ntsc promo only music video
By jamespoo in forum Video ConversionReplies: 14Last Post: 24th Mar 2011, 16:12 -
Verbatim -Rs at Newegg:
By wtsinnc in forum MediaReplies: 6Last Post: 4th Sep 2009, 00:02 -
Backgrounds for 8x10 promo shots?
By sdsumike619 in forum ComputerReplies: 1Last Post: 12th May 2009, 20:46 -
Football Promo
By 2Tents in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 8th Aug 2007, 15:04 -
Newegg - any non-US users?
By rhegedus in forum ComputerReplies: 5Last Post: 30th Jul 2007, 17:03
