I am new to all of this and am trying to soak all of this in. I have DVDs that I would like to make a copy of and save on my NAS device. I want to record the data to get the highest quality output so when I watch it, it looks as good as the DVD (if possible). I don't care about hard drive space since I have a NAS. I don't care how long it takes to rip the DVDs since I want to do this only once and have a high quality file that I can stream.
The plan is to take this file and stream it to my PS3 over ethernet. So, I have played with AnyDVD, DVDshrink, DVDFab, Handbrake, etc and I'm not sure what the best way to do this.
So, what sofware do I use and what format should I store it in to get the highest quality? It would be nice to remove the Copyright warnings/filler and also have the chapters stored.
I guess the other side thing is that I want to be able to copy the file to my iPhone to watch it on my phone. I understand that I will probably need to create a second file that is smaller for my iPhone.
Thanks in advance for the tips..
XVID4PSP using the M2TS option.
Well since you don't care about HDD space, then rip your DVDs with Shrink and save to one single VOB...
Open Shrink>Load DVD or open folder>Edit>Preferences>Output files> uncheck "Split VOB files into 1GB size chunks" >OK and save to HDD
Stream the one vob to the PS3...Hope it helps
You can always use XviD4PSP for your other conversions..It works great!
BTW..just to be clear,
I don't have a NAS device ,but I do stream to the PS3 with TVersity...." Who needs Google, my wife knows everything"
Want to rip from interlaced DVD's in highest/same quality!
By DARkTYranno in forum DVD RippingReplies: 17Last Post: 22nd Feb 2012, 17:05 -
Trying to do HD-DVD to BDMV for streaming to a PS3...and have a problem
By trimicada in forum Video Streaming DownloadingReplies: 6Last Post: 4th Oct 2010, 21:11 -
Highest Quality XVID to DVD
By Merkaba188 in forum Video ConversionReplies: 10Last Post: 1st Jan 2009, 22:58 -
DVD converting for PS3 streaming
By Coxroach1 in forum Video Streaming DownloadingReplies: 3Last Post: 7th Aug 2008, 11:18 -
How to get the Highest Quality from DVD -> xVid or whatever is better?
By mistafro in forum ffmpegX general discussionReplies: 10Last Post: 22nd Aug 2007, 14:25
