When I try to convert an AVI file to h.264 using the iPhone preset, all it gives me is white video with the soundtrack.
I'm running a brand new mac with Leopard. I have tried this with multiple AVI's and they are all playable in VLC before conversion but after they get all screwed up. I just converted a short youtube video that was already in an iPod playable format and it worked nicely using the iPod preset.
What is wrong? Please help.
Chances are that these AVI source files do not display the video in your current setup of QuickTime Player either. By default, the iPhone preset uses QuickTime to read ("decode") the source file. It is an option (checkbox) in the Options tab.Originally Posted by 911alertme
- You could de-select "Decode with Quicktime" to make ffmpegX use ffmpeg for decoding.
or
- You could add a component to QuickTime to help it decode more kinds of video. Then ffmpegX will be able to convert your source video while using QuickTime for decoding. The developer suggests (product requirements) 3ivX or DivX. Perian will also help QuickTime decode DivX/XviD, as well as many other codecs and features. One of these three will do.
VLC plays just about anything, so that doesn't mean a lot when it comes to compatibility with other conversion apps, such as ffmpegX.Originally Posted by 911alertme
By default, the 3GP preset doesn't use QuickTime to decode the source file, but it uses ffmpeg to decode it.Originally Posted by 911alertme
DVD video appears distorted/shaking on sides when played on TV
By Blueknight in forum DVD RippingReplies: 0Last Post: 6th Feb 2011, 16:48 -
When my video renders, the letter "T" appears as a random symbol...
By alexstills in forum EditingReplies: 1Last Post: 1st Feb 2011, 13:40 -
Black borders appears in DV video
By Fanda@CZ in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 13th Nov 2010, 02:39 -
Any way to capture this video as it appears on the 'net?
By brassplyer in forum Video Streaming DownloadingReplies: 3Last Post: 17th Dec 2008, 18:09 -
Green subs appears on DVD but even when I rip it, on PC i'ts white!!!
By cemman in forum SubtitleReplies: 3Last Post: 21st Jun 2007, 14:57
