Trying to use the mpg file created by svcd2dvd to save 2 1/2 hours processing time to see if I can add Menus
Here is the error I got
Version: SVCD2DVD 2.5
Build: 2.5.3600.0
Type: System.AccessViolationException
Source: System.Windows.Forms
Message: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
InnerException:
StackTrace: at System.Windows.Forms.UnsafeNativeMethods.DispatchM essageA(MSG& msg)
at System.Windows.Forms.Application.ComponentManager. System.Windows.Forms.UnsafeNativeMethods.IMsoCompo nentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData)
at System.Windows.Forms.Application.ThreadContext.Run MessageLoopInner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.ThreadContext.Run MessageLoop(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.Run(Form mainForm)
at x3284ccece41ee22b.x210ff09a2516b1a7.xc447809891322 395(String[] xce8d8c7e3c2c2426)
Can you post your log?
Were you using 2 pass encoding? If so try again with 1 pass.Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
No using 1 pass that's default right? I never get that far as soon as I drag asset to vts panel it locks up and have to use taskmanager to kill process.
One pass should be the default, still need to see the log from the run that created the mpg. What is the reported size of the mpg file?
Dwight
- Herm Albright
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 08:58 -
Error loading .sup files to GfD?
By michcio in forum SubtitleReplies: 0Last Post: 13th Dec 2009, 12:08 -
Error loading assest
By ttyner in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 28th Jan 2009, 11:40 -
svcd2dvd not loading aftere service pack 1 vista 64bit
By lindakay in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 18th Apr 2008, 04:23 -
SVCD2DVD io.Exception on loading
By gfbuchanan in forum SVCD2DVD & VOB2MPGReplies: 22Last Post: 18th Nov 2007, 12:26
