Hello!
Could you give me an advice?
I have two Final Cut Studio projects, shooted using Mini HDV tapes of a JVC HD100E camcorder. Shooted at 720p.
I use DVD Studio Pro.
Once finished the editing, I need to burn a DVD for each video, downscaling to SD.
Each video lenght is <5 min.
So, I think that if a DVD can store two hours of SD video, and a video of mine is a 4 minutes video, I could make an "uncompressed" DVD!
This because I need the maximum quality, and since the project is already compressed once (the HDV minitape), if I make a DVD I compress it twice!
Even if a very low compression ratio, it loses quality a lot!
DVD Studio Pro hasn't any option like an "uncompressed DVD", or to reduce the compression to zero (like the Win Zip "zero compression - store" option...).
Could you give me any advice? Is there a software? a plug-in? Freeware or trial is better...
Thank you!
I don't use Mac, but maximum video bitrate for DVD-video is 9800kbps, assuming you want to play it on a DVD player (not a data disc). If you go over that, it won't play on a standalone unit.
If you look in the top left corner, there is a section called "what is" and just hit DVD https://www.videohelp.com/dvd
Just set close to the maximum bitrate in your software
If you want better quality, you might consider better formats, like AVCHD on a blu-ray, but you need a different hardware setup. You can put AVCHD on a normal DVD-R, and play it in a PS3 for example -
OK I understood!
The problem is the player unit...
Do you think that a not so big television station could broadcast a AVCHD DVD-R or BlueRay disc? -
You cannot make an uncompressed DVD. DVD format requires that the video use either MPEG-1 or MPEG-2 and nothing else. Both MPEG-1 and MPEG-2 compress.
I disagree that "even if a very low compression ratio, it loses quality a lot!". If you don't like DVD quality than you should use BluRay as poisondeathray says. -
I'm not sure what you are asking, but some European channels broadcast transport streams with h264 in 1080i (e.g. BBC, Sky HD)Originally Posted by ununpentium
OK thank you very much guys!
I have another question:
I use:
1) Athlon XP 2000+ with Win XP Pro 32 bit SP2
2) Mac Pro with OS X 10.4 and Final Cut Studio 2
I have the video file, that I can make using Final Cut exporting in virtually any format (uncompressed or compressed AVI or MOV or other file...).
How can I make an AVCHD DVD?
Is there an utility, converter, AVCHD iso image creator/burner or other? Freeware or Free trial is better...
Thank you!
DVD Recorder vs Huffyuv Uncompressed
By jrodefeld in forum Capturing and VCRReplies: 23Last Post: 11th Jul 2011, 09:22 -
Convert uncompressed avi to DVD
By sastek in forum Newbie / General discussionsReplies: 2Last Post: 28th Apr 2011, 21:47 -
I need to make default uncompressed audio again!
By Artas1984 in forum AudioReplies: 1Last Post: 8th Jan 2011, 16:04 -
Exporting from uncompressed AVI to uncompressed MOV
By courtneye in forum Video ConversionReplies: 0Last Post: 9th Jul 2010, 08:20 -
how to make ffmpeg recognize an uncompressed quicktime source file?
By eighth in forum ffmpegX general discussionReplies: 0Last Post: 21st Dec 2007, 14:09
