    Sep 2008
    Hello there, I've been recently trying to get the PAL60 option to work on my capture cards, but none of them that I have right now don't seem to support it.
    I've already read a few topics here but I'm still not sure what the answer to this is, so my question is, if I decide to use a S-video video cable from the console to my capture device, will I be able to get a neutral signal? (As in, will it record PAL60 properly, or does it not work this way?)
    If not, would you recommend the Easycap/Kworld that seems to support the NTSC_433 option?
    Thanks in advance.
  2. Anonymous
    Guest
