I've long used GoldWave and SoundForge. But I wanted to see what else was out there.
I have both SoundBooth and Audacity, but really haven't really found them to be of much use when restoring audio.
I used to use DartPro '98, but it would not function in NT environments, abandoned when I moved to Windows XP some years ago. The new version is at http://www.dartpro.com/Main/TryDP24.asp
Here's some of the ones I've started to try out or research:
http://wavearts.com/products/suites/master-restoration/
http://antarestech.com/products/
http://bias-inc.com/products/soundSoapPro/
http://izotope.com/products/audio/rx/
http://diamondcut.com/osc/product_info.php?products_id=63
There was a good article in DV magazine a few months ago, how I got the lead on this.
It depends what you're trying to do.
For general noise (i.e. hiss) reduction, I like this...
http://www.sonycreativesoftware.com/noisereduction
...mode 2 is especially useful.
However, the evaluations I've carried out have mainly been for restoration of very old records (i.e. 78s) in something like real time - some supposedly "good" software is quite useless for this.
Cheers,
David. -
What type of restoration do you want to do? I found Izotope RX a while back. It's really good at noise removal and declipping.
for tapes, vinyls sounds in bad condition in general you better try wave arts filters which are VST plugins
http://wavearts.com/*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
I have used Syntrillium's CoolEdit 95, 96, and CoolEdit Pro, which was bought by Adobe and released under the brand, Audition. FWIW, I have restored over 1000 audio cassette tapes. (I am a noob for video.) My procedure generally is this:
- Record on good 24-bit/96-kHz hardware or better (I use EchoAudio with good cables, etc.)
- DeClick-DePop
- DeNoise (find noise sample, learn profile, remove everywhere - tweak as needed). This is the most time-consuming interactive step.
- Optional: Use Dynamic Compressor to reduce dynamic range
- Normalize to 100%
- Downsample to 16-bit/48-k or 44.1kHz
The batch scripting capability makes the tool invaluable to me.
*OLD* CD Restoration
By kallisti5 in forum RestorationReplies: 13Last Post: 6th May 2011, 07:11 -
mp2ts audio restoration
By R55B in forum AudioReplies: 1Last Post: 9th Jan 2011, 10:05 -
Another post that's a mix of Audio, Editing and Restoration...
By takearushfan in forum Newbie / General discussionsReplies: 2Last Post: 11th Feb 2010, 02:00 -
VHS restoration
By degacci in forum RestorationReplies: 5Last Post: 5th May 2008, 02:02 -
Restoration
By KMJvet in forum MacReplies: 15Last Post: 15th Apr 2008, 17:08
