  1. I am having an amazing problem, am backing up my friends collection he has recorded using a LG dvd recorder in Canada.
    It is almost like the dvd's were recorded in some strange Martian method, using Nero I get LBA errors, using img burn most will copy but when they do not I get a read error on far too many dics sfor it to be the media (!?), may be not.
    The discs even seem to be jamming up my pc's sometimes.
    I have never experienced this.
    Here is some techno info using various dvd software.
    Nero InfoTool 4.4.3.0
    Drive Information
    Drive : HL-DT-ST DVD-RAM GSA-H22N
    Type : DVD±R/RW DL Recorder
    Firmware Version : 1.02
    Buffer Size : 2 MB
    Date : 07-01-31
    Serial Number : 49>8;(
    Vendor Specific : 07/01/31
    Drive Letter : H:\
    Mechanism : Tray
    Read Speed : 16.0 , 12.0 , 8.0 , 5.0 , 4.0 , 2.0 , 1.0 X
    Write Speed : 12.0 , 8.0 , 4.0 X
    Read CD Text : Yes
    Return C2 Pointers : No
    Read CD-R : Yes
    Read CD-RW : Yes
    Read DVD-ROM : Yes
    Read DVD-RAM : Yes
    Read DVD-R : Yes
    Read DVD-RW : Yes
    Read DVD-R DL : Yes
    Read DVD+R : Yes
    Read DVD+RW : Yes
    Read DVD+R DL : Yes
    Read BD-ROM : No
    Read BD-R : No
    Read BD-RE : No
    Read HD DVD-ROM : No
    Read HD DVD-R : No
    Read HD DVD-RW : No
    Read HD-BURN : No
    Read Digital Audio : Yes
    Read CD+G : No
    Read VideoCD : Yes
    Write CD-R : Yes
    Write CD-RW : Yes
    Write DVD-R : Yes
    Write DVD-RW : Yes
    Write DVD-R DL : Yes
    Write DVD+R : Yes
    Write DVD+RW : Yes
    Write DVD+R DL : Yes
    Write DVD-RAM : Yes
    Write BD-R : No
    Write BD-RE : No
    Write HD DVD-R : No
    Write HD DVD-RW : No
    Write HD-BURN-R : No
    Write HD-BURN-RW : No
    Buffer Underrun Protection : Yes
    Mount Rainier : No
    SolidBurn : No
    Labelflash : No
    LightScribe : No
    Modes : Packet, TAO, DAO, SAO, RAW SAO, RAW DAO, RAW SAO 16, RAW SAO 96, RAW DAO 16, RAW DAO 96
    HL-DT-ST DVDRAM GSA-4163B AN16 (ATA)
    Current Profile: DVD-ROM
    Disc Information:
    Status: Complete
    Erasable: No
    Sessions: 1
    Sectors: 2,292,400
    Time: 509:27:25 (MM:SS:FF)
    TOC Information:
    Session 1... (LBA: 0)
    -> Track 01 (Mode 1, LBA: 0 - 2292399)
    -> LeadOut (LBA: 2292400)
    Track Information:
    Session 1...
    -> Track 01 (LTSA: 0, TS: 1520, LRA: 1519)
    Pre-recorded Information:
    Manufacturer ID: ProdiscF01
    Recording Management Area Information:
    LGE Inc LGRL-05A
    Physical Format Information (Last Recorded):
    Book Type: DVD-R
    Part Version: 5
    Disc Size: 120mm
    Maximum Read Rate: Not Specified
    Number of Layers: 1
    Track Path: Parallel Track Path (PTP)
    Linear Density: 0.267 um/bit
    Track Density: 0.74 um/track
    First Physical Sector of Data Area: 196,608
    Last Physical Sector of Data Area: 2,489,007
    Last Physical Sector in Layer 0: 0
    It might be the media, VicB.
    This is one of those problems where I simply have to tell people to mail me the discs, and I put it into all of my drives. In cases like this, I can usually recover 50-75% of the media (for a price, of course), but the other 25-50% is toast.
    Honestly, your LG drives are not very good -- not even close -- at reading discs. It could be as easy as trying another drive -- Pioneer is suggested.
  3. Thanks LS.
    When you say LG not good at reading discs do you mean from the data I supplied or just in general, and is their reading suspect rather than their writing. as I have never had this problem in 4 years of using them until I started this project and imgburn is having success whereas Nero cannot read any.
    And on one that neither imgburn or Nero would read, TMPG express read it fine and I was able to scroll through the whole recording with that software !
    Some of the discs have surface scrtaches but pressed ones I've done read fine with worse marks.
    It seems that the original dvd recorder has created some weird formatting, but like DVD-VR rather than dvd video?
    Appreciate it.
  4. In case anyone is interested !, I seem to have found the problem, I am using 4163B with H-22N on both of my PC's and it seems the 4163's are a bit long in the tooth, as if I use h-22N to read and 4163 to write I am getting much more success.
    PAL/NTSC problem solver.
    USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS
