    Jul 2004
    Are they using green/blue background effect with the guy talking in the front?
    How can I achieve the same thing in Adobe After Effects? Thanks.
    Using the same idea.. capture the first raw video.. and capture the second video with green/blue in the background?
    http://www.youtube.com/watch?v=oleLJEtiC00
    USA
    Some background info on chroma keying: http://en.wikipedia.org/wiki/Bluescreen
    More info: http://www.seanet.com/~bradford/blue_green_screen_visual_effects_1.html
    Or since you mention YouTube: http://www.youtube.com/watch?v=w6brdwY-dvU
    I don't think After Effects can do it, though, at least without some addons.
    You can also do a internet search for ' chroma keying ' and find more.
    EDIT: I was probably wrong about AE not being the proper tool. After some searching: http://www.google.com/search?hl=en&q=adobe+after+effects+green+screen&btnG=Search
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    AE Pro Bundle should be able to do it with ease with keylight. Standard edition also has a wealth of keying tools.
    Read my blog here.
