This problem just started yesterday and I have no clue what is causing it. Up until this point I have had no problems playing anything back. Currently, when I play 720p x264 files, typically rips of TV shows, at any given point the screen goes white or gray, with a random mix of colored lines across the screen. The curser turns into a block of the same lines, usually gray or white with lines across it. It happens in wmp, wmp classic, VLC and every other player I've tried. VLC runs choppy on 720p playback to begin with so I prefer not to use it, but up until now wmp and wmp classic played it beautifully. I tried switching to the CoreAVC professional codec based on something i'd read in a few forums, and now everything runs like garbage. Even my standard 624x352 Xvid rips are running a bit jumpy now. I've uninstalled coreavc and went back to the K-lite pack which worked great before, and it just doesn't look right. Is this a codec/software problem, hardware or what? Any and all help is insanely appreciated. I'll attach a picture after it happens again
An apology is a good way to have the last word
and this time it went all black, backlit, but all black, with audio still playing, then turned into this
100_2196.jpgAn apology is a good way to have the last word -
Looks like videocard might be overheating (and/or your CPU), or a driver conflict issue
Check your temps, try updating your drivers -
I'm not sure which drivers to go with. I have a feeling it started with a windows update which possibly changed the driver. What is best for my graphics card?Originally Posted by poisondeathray
Nvidia system monitor is reading my gpu temp at 65c and speed fan is reading my cores at 50-60c. I can't find a straight answer anywhere if this is too high or average. This is while sitting on a cooling stand (although not a great one - just a little rocketfish single fan job that keeps it from melting my lap).An apology is a good way to have the last word
Crash on video playback
By tomsalinsky in forum Software PlayingReplies: 2Last Post: 14th Mar 2011, 05:51 -
x264.exe crash in xvid4psp
By hasteroth in forum Video ConversionReplies: 2Last Post: 30th Dec 2010, 15:58 -
Playback advice on x264 video
By strontium_99 in forum Software PlayingReplies: 7Last Post: 30th Oct 2010, 06:58 -
Ipod Video playback causes crash
By RKelly in forum Portable VideoReplies: 3Last Post: 10th Sep 2008, 17:00 -
How can i playback avc (h264,.x264) video?
By therock003 in forum LinuxReplies: 13Last Post: 29th May 2008, 15:56
