    Sep 2008
    I AM A NEWBIE AND HAVE STARTED TO USE NERO. FOR SOME REASON I WILL GET THE PICTURE FOR THE DURATION OF THE DVD BUT THE SOUND DISAPPEARS AFTER A COUPLE OF MINUTES AND NEVER RETURNS. HOW CAN I FIX THIS ? IT HAS HAPPENED TO MORE THAN ONE OF MY MOVIES I HAVE RECORDED. THANK YOU
    USA
    NOT ENOUGH INFORMATION AND TYPING IN ALL CAPS IS IRRITATING TO OTHER POSTERS AND NOT RECOMMENDED IF YOU WANT REPLIES. IT IS CONSIDERED SHOUTING ON THE NET.
    Nero is generally not a good converter and I would try something else. What format are you converting from? You can use Gspot to find out. I assume you are converting to DVD MPEG format.
    And welcome to our forums.
    Sep 2008
    sorry about the typing was not aware of forum etiquet. yes you are correct dvd mpeg format. idowload information and am able to watch and hear it on windows media player. but when it comes down to transfering it, the sound is there in the begining and then all of a sudden the sound is gone, but picture is ther?
  4. Mod Neophyte redwudz's Avatar
    USA
    It seems odd that the sound would disappear. If you are doing AVI type format to DVD, try FAVC or Avi2Dvd or DVDFlick. They are all freeware. Or try the payware ConvertXtoDVD. I have no idea what Nero may be doing.
    I would also try playing back the VIDEO_TS folder on your computer after Nero or other tools create it. You can use VLC Media Player for that. If the audio is there, maybe a burning or media problem, though that is unlikely.
    Sep 2008
    thank you for your time. i will try your suggestions as soon as possible.
    Sep 2008
    I NOTICED IF IT SAYS FASTPASSTV ON THE FILE THAT IS WHEN I LOSE THE SOUND OF THE MOVIE DO I NEED WINDOWS AUDIO CODECS? as a newbie i know there are many options to use for downloading and burning a movie. my computer already came with nero. i am learning to use it and my first couple have come out with picture but no sound should i choose a different program r am i doing something wrong?
