  1. Guest
    Are there any program to do this conversion? I tried VirtulDub and it seems like it no longer support ASF files. And why are some movie/video clip can't fastward? esp. ASF files, I walways jump back to where it's playing when I try to click the cursor to fastward. Does anyone know why? thx
  2. Use a program called ASFTools. You should be able to download it in the Tools section of this website. It can convert your ASF files to AVI and then you can use TMPEG to encode it into a MPEG. You should also download the dB Poweramp Music Converter. You would use it to create a wave file out of the ASF file and then use it for the audio source in TMPEG.
    Feb 2001
    Kalmar, Sweden
    ...you could also use VirtualDub 1.3c that also can convert ASF->AVI...
    Magnus Jensen
    A.K.A Geezus
  4. I have tried Vdub 1.3c and I always get some kind of error message whe using asf files. I've found that the ASFtools works better for me.
    Feb 2001
    Kalmar, Sweden
    Ok, you learn something new every day =)
    Magnus Jensen
    A.K.A Geezus
