Using Vegas Pro 8.0, I have 2 miniDV tapes that I need to transfer (no editing) to DVD. So one tape is full 1hr, the other is probably 15 min of footage. How can/should I render these 2 tapes to fit onto 1 DVD? Usually I use the DVD Arcitect template (MPG2) as render option. What options in the video properties should I change if any so that DVD Arcitect will fit onto a single layer 4.7gb disc?
Use the bit rate calculator. Enter 1hr 15 min.
https://www.videohelp.com/calc
The calculator reports 7903 Kbps for average bit rate. I'd back off to 7500 kbps ave. to allow for some file size variability. Two pass encoding makes a more predictable file size.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Sony Vegas Pro 11 Question: Video in Preview and Finished Render "Choppy"?
By MoreThanLuck in forum EditingReplies: 7Last Post: 31st Dec 2011, 20:17 -
Cannot render to widescreen in neither vegas 7 or 8
By 2prfm in forum Video ConversionReplies: 1Last Post: 7th Sep 2010, 08:38 -
Vegas Batch Render?
By duderdude2 in forum EditingReplies: 1Last Post: 28th Feb 2010, 02:42 -
Sony vegas settings for render question.
By ingeborgdot in forum EditingReplies: 25Last Post: 25th Oct 2009, 20:27 -
Vegas Render Still Sequence
By vegasarian in forum Newbie / General discussionsReplies: 1Last Post: 4th Jun 2007, 07:39
