Hi,
I'm not sure if this is the right forum for these questions. If its not and anyone can recommend one then please do.
The rules said not to post any links, but a quick search should take you to the tutorial page if you do not already know
about it.
Has anyone tried and been able to get this tutorial "Large MKV (h264) File to PS3 MP4 « Just Another Odd Man Out" to work.
The first problem I encounter is with the aac audio file exported from ffmpeg — I always get a loud distorted file. The next
problem is using HexEdit to convert the video from a 5.1 profile to a 4.1. I open the file in HexEdit and change
67 4D 40 33 to 67 4D 40 29 then save the file, but when I open it i MediaInfo Mac the profile is still 5.1. The final problem
occurs when trying to interleave the video and audio files — the mp4 files doesn't work in QT or anything else.
Alternatively does anyone know of a reliable way to change the video profile from 5.1 to 4.1 on the Mac. If I can do that then I can use MKVTools to create a usable mp4 file.
Thanks,
Terrence
Results 1 to 1 of 1
MP4/h264 Exact File Size Encoding
By Trismegistus in forum Video ConversionReplies: 1Last Post: 23rd May 2010, 09:57 -
H264 to MP4 for PS3 or XBOX360
By DVDONE in forum Video ConversionReplies: 4Last Post: 27th Mar 2010, 16:07 -
Large H264 MP4 to DVD?
By Merkaba188 in forum Video ConversionReplies: 3Last Post: 17th Oct 2009, 18:30 -
H264/AC3 (MKV) to H264/AAC (MP4) ?
By jccca in forum Video ConversionReplies: 10Last Post: 13th Dec 2008, 20:06 -
Large[19.5GB] VOB to MP4[H264]
By madmillington in forum DVD RippingReplies: 3Last Post: 6th Feb 2008, 15:40
