im trying to covert an AVI (divx) file to dvd format i used dvd flick, windows dvd maker and NTI dvd maker 7. all encoded but when playing back from dvd on computer or dvd player the audio track drifts out of sinc with the video. the main avi file plays just fine. i tried different burning and encoding speeds provided the those programs but the same thing. anybody have any suggest i might check into or try to eliminate this problem? i also have the latest klite codec pack installed unless there something else in addition i need![]()
Originally Posted by Baldrick
Thanks for the suggestion for trying FAVC but favc is not reconizing my avi file i ran the file through mediainfo and here's the info:
DIVX: 1.55 GB, 2hr 55mn
1 video streams: MPEG-4 Visual (DivX 5)
1 audio streams: MPEG Audio (MP3)
First video stream
1 500 Kbps, 720*400 (16/9), at 29.970 fps, MPEG-4 Visual (DivX 5)(Packed bitstream)(BVOP)
First audio stream
128 Kbps, 44.1 Khz, 2 channels, MPEG Audio (MP3)(Version1)(Layer 3)(Dual Mono)
should FAVC be able to handle this? do i need to reinstall favc, avisyth and/or net framework?. maybe downgrade (convert) the avi Divx file to a regular avi file or other format for FAVC to reconize without video quality loss?
My intial post is as follows:
Baldrick
Administrator
Posted: Sep 29, 2008 17:23
I would try convert using FAVC.
If that wont help then give us the AVI details. Use MediaInfo and post all details here. -
Yes, FAVC should support avi divx with mp3. WHat is the error message in favc?
THe avi headers might be corrupt so I would try run divfixpp on the avi.
Or try latest version of ConvertXtoDVD. -
Sometimes just running an AVI through this will fix things.
http://www.alexander-noe.com/video/amg/
Especially if you see 'bad'. It will also set the delay to zero.
ASF2VC1 & transcode the audio WMA to AC3, then mux video VC-1 and audio
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 9th Jan 2010, 08:02 -
How to combine video with audio file and replace audio with video files ?
By designbuyers in forum Newbie / General discussionsReplies: 2Last Post: 8th Feb 2009, 11:12 -
Video8 Head Misalignment?
By frozentax in forum Newbie / General discussionsReplies: 6Last Post: 1st Dec 2008, 19:59 -
Syncing spearate audio/video: Better to stretch/shrink video than audio?
By stantheman1976 in forum EditingReplies: 15Last Post: 16th Jan 2008, 04:14 -
Converting an AVI video with AC3 audio to an AVI video with MP3 audio
By rijulHKG in forum AudioReplies: 1Last Post: 15th Jul 2007, 00:23
