Hello,
This is my first post on this website and was wondering a few things about my capture card.
I have a Dazzle Creator Plus (DVC 107)
and i've captured videos from my TV out composite ports of my TV, till now the capturing i get is very interlaced.
here is a video I made that was very interlaced
http://www.youtube.com/watch?v=g6G8XHHV36U
Also the quality looks so bad,
My computer might be the reason as it is running at 1.61Ghz but has sufficient RAM 1.25GB
but my main question is, people on youtube just use Y splitters and get good quality with minimal interlacing.
So i was asking if using splitters would be a better option instead of my TV's out.
Thanks for any help
try setting your encoder to de-interlace as part of the encoding process. computer displays need progressive video. capture using the highest quality settings your software allows, and then encode to flv with de-interlacing for youtube. splitters won't give you any better video.
My encoder won't do de-interlacing but will do progressive instead of interlacing, but when I use progressive it becomes very laggy, almost looking like the video skips, this problem might be because of my processor as the capture card box states to have atleast 1.8 Ghz of CPU but is recommended to have 2.4Ghz and above and I only have 1.61Ghz at the moment.Originally Posted by minidv2dvd
Though I have to admit that progressive gets rid of the interlace very well but brings up the issue of objects having doubles of them.
Would having component instead of composite help at all? -
We need a LOT more info on exactly what you are doing here if you want help.
What is your encoder?
What is your final format it produces?
What are format and settings are you using when you capture your video?
You also need to understand what interlacing means because you either have it or you don't. Saying your video is "very interlaced" or has "minimal interlacing" is not an accurate description of what is going on. Well, actually if you have some bastardized mix of interlaced and progressive video that latter one could be true, but I don't see how a Dazzle card would do that.
Finally, note that video game captures are a real bitch and people have all kinds of trouble doing that. It's not for novices. -
Originally Posted by jman98
Encoder= Pinnacle Studio 12, ( then encoded to MPEG4 with Xilisoft Video Converter)( I dont think it supports de-interlacing when encoding either)
Format= MPEG 2
Bitrate = 5500 kbps/s but can do 10,000 kbps/s MAX
Take a look of some of the Tests I made
The softwares settings are set to interlaced here in this video
Very Interlaced during 00:34 - 00:38
This Video I also made is in progressive but skips a bit here and there and also looks interlaced as well
http://www.youtube.com/watch?v=f9OQ5BuXq_Y
I heard sony vegas is also a greatcapturing software with de-interlacing options, will take a look at that as well.
Also an update: I returned the dazzle capture card and buying Pinnacle MovieBox Ultimate to see if thre's any differences. -
What you describe consistently as "very interlaced" is actually called "ghosting". Various things can cause ghosting. I am wondering if you are doing some resizing too as this can also have a negative effect on your final output if it's not done properly.
You may be better off with the Pinnacle device. Years ago Dazzle made one of the very best PCI based video capture cards in the old DVC-II, but their products since then have just about all been USB based and nobody seems to think much of those. -
Yea almost forgot that the video is also resized from 720x480 to 640x480
don't know if that causes much problems but, the ghosting only comes in in one of the videos which I deleted and don't have anymore.
I also wanted to know how the people on youtube get better quality than me using splitters only instead of TV out.
Also my RCA cables are great quality as well. I thought using splitters migh have been a different story.
I was wondering if the MovieBox Ultimate listed below would have better quality than the Dazzle.
http://www.pinnaclesys.com/PublicSite/us/Products/Consumer+Products/Home+Video/Studio+...version+12.htm
Dazzle Vid Creator Plus, or TV tuner card?
By cwb in forum Capturing and VCRReplies: 3Last Post: 21st Jul 2009, 09:38 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 11:45 -
dazzle capture card help
By brian2391 in forum Capturing and VCRReplies: 1Last Post: 2nd Mar 2009, 11:45 -
Dazzle dvd recorder capture card and a VCR problem
By leeh in forum Capturing and VCRReplies: 5Last Post: 3rd Jul 2008, 14:53 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
