Hi,
I have an audio clip of a person talking while the phone ring.
How can I remove that phone ring and which software?
Also, I want to remove all other noise beside the person is talking.
Thanks a lot.
The short answer is that you can't. The long answer is that is you play around with an audio editing package such as Audacity (free) or Sound Forge (not free) and use the EQ and notch filters you may be able to reduce some of the noise. Usually this comes at a cost to the fidelity of the stuff you really want though.
Read my blog here.
Can I crank up my low audio to high audio without turning up the speaker volume? The person has a soft voice. thx
As you said - HE can't do it, but it is perfectly doable, albeit time-consuming and require more than basic knowledge.Originally Posted by guns1inger
If the said phone ring is one of the usual modern electronic buzzers (or old fashion style ring), it may be easy to do. Its pattern and frequencies shouldn't be that hard to locate and remove. If its some melody (like mp3 ringtone or such) it may get more complicated.
Certainly I'd suggest to try Sound Forge (if there is trial version). -
I like Sound Forge, but it isn't cheap. Audacity can do a lot of the same things for free, you just have to think a bit harder about how. Goldwave is also good, and Audition has it's fans.
Read my blog here.
Best Program to Remove Audio from VOB and insert another Audio
By Zhuge Liang in forum Authoring (DVD)Replies: 1Last Post: 16th Feb 2012, 03:42 -
How to remove spanish audio?
By skorpinok in forum Video ConversionReplies: 1Last Post: 6th Jan 2012, 11:06 -
No Audio On AVCHD-DVD, How To Remove Other Audio Tracks From MKV File First
By elistian in forum Video ConversionReplies: 1Last Post: 14th Dec 2009, 07:03 -
How do I remove audio?
By martyw in forum ffmpegX general discussionReplies: 2Last Post: 14th Sep 2009, 00:08 -
Remove audio with FAVC
By marioval in forum Authoring (DVD)Replies: 2Last Post: 14th Feb 2008, 08:04
