Video
Format : RealVideo 4
Codec ID : RV40
Codec ID/Info : Based on AVC (H.264), Real Player 9
Duration : 2h 0mn
Bit rate : 534 Kbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 5/4
Frame rate : 25 fps
Standard : PAL
Resolution : 12 bits
Bits/(Pixel*Frame) : 0.051
I customize my mpg from rmvb in actual width and height.
How about aspect ratio 5/4?
I can't find it at Tmpgenc xpress. It got 1:1, 4:3 and 16:9 only.
Should I put 1:1?
No, you make it either 4:3 or 16:9. It'll still be 720x576.
This thing must look like utter garbage already.Bits/(Pixel*Frame) : 0.051
Bit rate : 534 Kbps
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
Tmpgenc xpress Image Resolution & aspect ratio
By sychern in forum Video ConversionReplies: 5Last Post: 24th Aug 2008, 09:25 -
16.9 Aspect Ratio with TMPGEnc dvd author 1.6
By GJF in forum Authoring (DVD)Replies: 22Last Post: 24th Jun 2008, 04:57 -
Tmpgenc Express: Aspect ratio problem
By shashidar in forum Video ConversionReplies: 1Last Post: 11th Mar 2008, 19:59 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
