I know that you can buy DVD movies that also include a bit of software. (You put the DVD in your computer to take advantage of the software). My question is: I have used Gui For DVD Author many times to make a DVD. But how can I also include software on the DVD? I want to include the mpeg2 codec folder (see screenshot). The added software folder should not affect normal watching of the DVD. The idea is that if the DVD won't play (due to lacking the mpeg2 codec) the user can easily install the codec.
You can do this with ImgBurn. Use build mode. Put your Video_TS and Audio_TS in the build box. Then insert any other files in the build box that you want on the disc. Then burn it to a DVD. The DVD will play normally but you will be able to access your other files on your computer.
Bluray to dvd ( include menus )
By pcb in forum Blu-ray RippingReplies: 7Last Post: 26th Apr 2010, 20:35 -
Question how to include software on authored DVD with Nero 6
By jimdagys in forum Authoring (DVD)Replies: 1Last Post: 1st Oct 2008, 11:13 -
How to include a 320x256 size video in a DVD
By dvdnewb2 in forum EditingReplies: 3Last Post: 18th Aug 2008, 08:19 -
How do I include wmv to a dvd with mpeg2?
By Jensen in forum Authoring (DVD)Replies: 6Last Post: 4th Jun 2008, 20:50 -
Software to make sure the audio and video of a authored dvd are in sync?
By snafubaby in forum Authoring (DVD)Replies: 7Last Post: 1st Oct 2007, 07:13
