Hi does anyone know a way to make a new partion on my hp touch smart computer. Theres a 400 gig hard drive which i want to split in half. I am running vista windows business on it. I really hated to leave windows xp on my other computer and now have this one.
You would need a program such as Partition Magic ( http://shop.symantecstore.com/store/symnahho/en_US/DisplayProductDetailsPage/productID...0/Currency.USD ). However, simply creating another partition won't make your PC dual bootable and you will likely need to reinstall XP and Vista (likely in that order) to get your PC to dual boot properly. In which case, you don't need any special software such as Partition Magic because you can do it from the XP CD.
Google is your Friend -
You might look at this guide: http://apcmag.com/how_to_dual_boot_vista_and_xp_with_vista_installed_first__the_stepbystep_guide.htm You can find other similar guides by searching the net for ' dual boot vista xp'.
I would also consider just adding a second drive instead for booting to XP. A external e-SATA drive will work the same as an internal one. One advantage is you wouldn't need to modify your existing drive.
JMO, but I would rather use Vista instead of XP after some time of using the OS.
Download the g-parted live ISO and burn a CD using imgburn. Boot to this to make your partition changes.
After that you are one your own. It is possible to build a dual boot XP Vista machine after Vista is installed, but it is a PITA. You are probably better off running XP in a virtual machine instead.Read my blog here.
Looking for free software to partition and backup netbook partition
By jimdagys in forum ComputerReplies: 4Last Post: 30th Nov 2011, 21:20 -
Revolution in computing - The New HP Touchsmart
By cplevel42 in forum Newbie / General discussionsReplies: 15Last Post: 10th Sep 2011, 02:50 -
How to Install Windows 7 O.S on new Internal Hard disk & make Partition ?
By skorpinok in forum ComputerReplies: 10Last Post: 26th Aug 2011, 06:13 -
HP Touchsmart 600 built in burner.... (HP-T633L)
By ironmanDD in forum DVD & Blu-ray WritersReplies: 2Last Post: 24th Feb 2011, 14:47 -
How to make a duplicate DV tape with computer?
By Captain Satellite in forum Newbie / General discussionsReplies: 12Last Post: 13th Dec 2007, 13:34
