Hi,
usually I would spend more time searching the forums (I did a quick search of the guides and didn't find what I was looking for), but I don't have time to do that today - sorry
I am using a capture card to capture videos in DVD quality as .MPG files.
The source unfortunately is mono on one channel, so I have to manually extract all audio, normalize it and copy the left channel into the empty right channel, then save the file as audio.
This part I have managed to do - Adobe Audition can extract MPEG audio.
So now I have MP3 files.
I have been using MPG2CUT2 to cut out the clips I need. In some cases the resulting clip is not working properly (e.g. audio can't be imported etc.), so I am also wondering if there is a freeware alternative for this, too.
But the main question is:
What freeware program can I use to replace the existing audio in the .MPG files with the new audio I create in Audition?
I don't care if it has to be WAV or MP3, I can always change that.
But I need a one-program solution that can replace audio in an MPEG file.
Batch processing would be a plus, but that may be much to ask in freeware...
Thanks a lot for any suggestion!
MP3 is not compatible with MPEG2, you can only use AC3 and MP2 audio
There are many free multiplexers (e.g. muxman, imagoMPEG-muxer, DVDAuthorGUI, about a dozen others in the "tools" section)
Replace audio on a DVD
By danielmak in forum MacReplies: 7Last Post: 31st Oct 2010, 23:40 -
Freeware for compressing DVD files
By Ricky_E in forum DVD RippingReplies: 59Last Post: 3rd Aug 2010, 14:11 -
Any freeware to index an mpeg2?
By mel2000 in forum Newbie / General discussionsReplies: 3Last Post: 27th Apr 2009, 11:11 -
How to combine video with audio file and replace audio with video files ?
By designbuyers in forum Newbie / General discussionsReplies: 2Last Post: 8th Feb 2009, 12:12 -
Freeware to replace audio track on a video file?
By gastrof in forum Newbie / General discussionsReplies: 2Last Post: 2nd Jun 2008, 22:54
